| corpselaurel |
Jun 17 2004, 11:02 AM
Member ![]() ![]() Group: Members Posts: 90 Joined: 15-April 04 From: usa Member No.: 1,931 |
I am wondering what all of you who don't have a lift do.
| r_towle |
Jan 3 2011, 08:09 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
engine hoist, right off the ground.
Bolt on the bars to the car. Pick up one end and put the two wheeled stand on it, put the pin in to hold the car level. Move the hoise back and pick up the back so the car is now level and the first two wheel piece you put on rolls up to plumb. Its simple and not scary at all. After its up in the air, install tie piece to tie the two end pieces together. Rich |
| Gudhjem |
Jan 3 2011, 11:21 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 29-March 07 From: Castro Valley, CA Member No.: 7,629 Region Association: Northern California |
engine hoist, right off the ground. Bolt on the bars to the car. Pick up one end and put the two wheeled stand on it, put the pin in to hold the car level. Move the hoise back and pick up the back so the car is now level and the first two wheel piece you put on rolls up to plumb. Its simple and not scary at all. After its up in the air, install tie piece to tie the two end pieces together. Rich Two wheeled stand? You mean the rotisserie stands? Hmmm, mine both have three wheels, and so the car has to be all the way up, and close to level, before I can fit the bumper attachments into the stand. They can't tilt forward, as I suppose they could if the third leg bolted on. |
corpselaurel Best way to get car on rotisserre Jun 17 2004, 11:02 AM
itsa914 I have never done it myself, but from what I read ... Jun 17 2004, 11:36 AM
maf914 I was thinking that if you had a big tree limb ove... Jun 17 2004, 11:55 AM
william harris Here's how I did it. For starters, my car was... Jun 17 2004, 12:34 PM
corpselaurel I was thinking of using 4 tractor jacks (they go u... Jun 17 2004, 01:21 PM
thesey914 Someone on this board used a fork-lift truck from ... Jun 17 2004, 03:23 PM
Carrera916 Another possibility is to use the engine "cherry p... Jun 17 2004, 03:30 PM
Racer Chris It is easy if you have an engine hoist.
Put hooks ... Jun 17 2004, 03:41 PM
Gudhjem "Put hooks (I bent 2 long 5/16 bolts) into th... Jan 3 2011, 07:43 PM
Vacca Rabite
Hmmm, mine both have three wheels, and so the c... Jan 4 2011, 07:22 AM
Richard Casto
For the sake of you and anyone working with you, ... Jan 4 2011, 08:18 AM
stugray "Hmmm, mine both have three wheels, and so th... Jan 4 2011, 06:34 AM
Gudhjem Going out on a limb here, I'm guessing that Ri... Jan 4 2011, 05:59 PM
Racer Chris
I'd like to go with Racer Chris's method ... Jan 4 2011, 09:04 PM
stugray "Going out on a limb here, I'm guessing t... Jan 4 2011, 09:56 PM
r_towle ok, IC the difference in designs.
I personally lik... Jan 4 2011, 10:45 PM
Gudhjem A follow-up:
I end up using a hoist attached as C... Jan 10 2011, 06:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:18 PM |
