| flipb |
Jan 5 2011, 08:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,870 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
Picked up my '74 2.0 this evening after getting a new set of EMPI 40mm's in place of the Weber Progressive that was on there when I bought the car last year.
Wow. It's like a different car. I was expecting a little better throttle response and less gurgling/flooding, but here's what I found: No gurgling or stumbling at all... big difference there. Instantaneous throttle response Quicker throttle take-up - I think the cable has less play than before. This is the biggest change and one I'll have to adjust to... I found myself revving to 3K RPM to get rolling in 1st gear. Got to get used to a softer touch. Smoother running at idle and throughout the rev band Big difference in sound.... this one I wasn't expecting. With the single Weber, there was a lot of burping, popping, etc, sounded pretty mean. Now it's got a deeper, throatier, smoother howl. Didn't touch the exhaust, but I swear there's a big difference in the sound. Can also hear the carbs sucking air at times. All of this is more impressive since I was driving home in 30-something degrees. The Weber carb had major issues with cold temps, due to fuel condensing in the intake runners. My mechanic also changed the trans fluid. So far I've only driven it ~10 miles on a scenic drive home from the shop. Hope I get another drive this week, although they're predicting snow... which means heavily salted roads. (IMG:style_emoticons/default/sad.gif) Oh, and here's my "ask": My mechanic had a very hard time getting the carbs dialed in. It's running rich right now, but he said the engine doesn't seem to like when he leans it out. Can others please share tuning/setup/jet sizing/etc. tips for my setup? It's new EMPI 40mm carbs on a stock 2.0 motor, for street use. Much obliged, and happy (IMG:style_emoticons/default/driving.gif) |
| BarberDave |
Jan 6 2011, 06:34 AM
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
You will love it , I felt mine was dangerous with the singel Carb. When your in a safe place to due this , Peddle to The Metal, Sweet music. Dave (IMG:style_emoticons/default/slap.gif) P.S. If you don.t have them allready get some ," Rain Hats " |
flipb Today, my 914 ia a little less "Progressive" Jan 5 2011, 08:36 PM
Joe Sharp The cars like to run a little rich, helps to keep... Jan 6 2011, 03:51 AM
Gint :agree: My dual Weber 2056 runs a little fat and ... Jan 6 2011, 05:50 AM
flipb
P.S. If you don.t have them allready get so... Jan 6 2011, 07:47 AM
Root_Werks
P.S. If you don.t have them allready get s... Jan 6 2011, 05:38 PM
flipb After bringing her home last night, I figured she ... Jan 6 2011, 07:51 AM
Vacca Rabite
If I top off the brake reservoir, is it safe to b... Jan 6 2011, 08:24 AM
Woody The fuel enrichment valves have a tendency to stic... Jan 6 2011, 08:57 AM
sean_v8_914 what is a "fuel enrichment valve"?
how ... Jan 6 2011, 09:13 AM
sean_v8_914 ps. winter tuning may be too rich in teh summer Jan 6 2011, 09:14 AM
yeahmag Damn... Just got back from Fairfax Station, VA. I ... Jan 6 2011, 12:00 PM
flipb
Damn... Just got back from Fairfax Station, VA. I... Jan 6 2011, 12:11 PM
zymurgist
Damn... Just got back from Fairfax Station, VA. I... Jan 6 2011, 03:06 PM
type47
Damn... Just got back from Fairfax Station, VA. I... Jan 6 2011, 04:26 PM
914rat
Damn... Just got back from Fairfax Station, VA. ... Jan 7 2011, 04:03 PM
flipb
[quote name='type47' post='1414391' date='Jan 6 2... Jan 7 2011, 06:57 PM
yeahmag No other mods needed... If the car felt "hard... Jan 6 2011, 12:12 PM
Vacca Rabite Its possible that the PO put one of the el-cheapo ... Jan 6 2011, 12:37 PM
Vacca Rabite It could also be somehting as easy as a split boot... Jan 6 2011, 12:38 PM
flipb
It could also be somehting as easy as a split boo... Jan 6 2011, 12:44 PM
Vacca Rabite
From the look of things before I left my house th... Jan 6 2011, 01:50 PM
flipb
From the look of things before I left my house t... Jan 6 2011, 01:58 PM
underthetire :agree:
With that much I would expect no pedal le... Jan 6 2011, 01:56 PM
r_towle First the carbs.
Find out what jetting you have on... Jan 6 2011, 07:21 PM
Spoke
you cant own one of these cars without jack stand... Jan 6 2011, 09:16 PM
geniusanthony I' m in alexandria on belvoir. Definately in f... Jan 7 2011, 09:22 PM
type47 There are informal Porsche gatherings for "br... Jan 8 2011, 09:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th March 2026 - 09:20 PM |
