| falconfp2001 |
Jan 7 2011, 09:22 PM
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I'm a noobie to the 914 but not to working on Air Cooled vehicles. Are replacement springs the only way to fix the sagging rear problem?
The car already rides kind of rough but I'd like a better height in the rear and a lower agressive stance in the front, while making it a smoother ride without the roll when cornering. Any suggestions? |
| detoxcowboy |
Jan 8 2011, 02:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Here is what I am trying to inform you, not low low but stock/lower than what you have now; I had what you have and just paying it foward...
This is bilstien allaround, 2nd from bottom rung on the rear and 1/2"-3/4" lower than the rear in the front... 4 wheel professional laser allighnment (a couple times now..ouch!)- I say ouch so that maybe you do all of your suspension at once and then get a pro allighnment once and save some $$$ If I remember correctly I am approx 5 3/4" off the ground from the rockers.... no bump steer and I can go into driveways and dips without issues or concern realy.. oh the tires are 205/60 not 195/65 so there is thatto consider in the picture, but the wheel wells are definately filled in nicely even with the lower profile tire, if you go /50's than there goes that.. ![]() |
| falconfp2001 |
Jan 8 2011, 06:48 PM
Here is what I am trying to inform you, not low low but stock/lower than what you have now; I had what you have and just paying it foward... This is bilstien allaround, 2nd from bottom rung on the rear and 1/2"-3/4" lower than the rear in the front... 4 wheel professional laser allighnment (a couple times now..ouch!)- I say ouch so that maybe you do all of your suspension at once and then get a pro allighnment once and save some $$$ If I remember correctly I am approx 5 3/4" off the ground from the rockers.... no bump steer and I can go into driveways and dips without issues or concern realy.. oh the tires are 205/60 not 195/65 so there is thatto consider in the picture, but the wheel wells are definately filled in nicely even with the lower profile tire, if you go /50's than there goes that.. ![]() Nice, Same color as my car. Attached image(s)
falconfp2001 Ride Height Jan 7 2011, 09:22 PM
SirAndy Any suggestions?
First, make sure your suspension ... Jan 7 2011, 09:32 PM
nsr-jamie I got mine from Tarret Engineering and they work v... Jan 7 2011, 09:36 PM
detoxcowboy I am riding a stock set up 74 2.0 with bilstien al... Jan 7 2011, 10:42 PM
falconfp2001 Didn't know that about the Bilsteins. The pric... Jan 7 2011, 11:33 PM
r_towle
Didn't know that about the Bilsteins. The pri... Jan 7 2011, 11:43 PM
detoxcowboy
Didn't know that about the Bilsteins. The pri... Jan 8 2011, 10:08 AM
bmtrnavsky
[quote name='falconfp2001' post='1415... Jan 8 2011, 08:46 PM
falconfp2001 Hmmm, Yeah, I'm not looking for low low. I jus... Jan 7 2011, 11:51 PM
r_towle its an 11mm wrench and a tape measure.
I measure f... Jan 7 2011, 11:56 PM
nsr-jamie
I measure ... Jan 8 2011, 07:27 AM
silver74insocal :agree: you can also get a bump steer kit for a f... Jan 8 2011, 12:19 AM
detoxcowboy Here are some helpfull links for what you may get ... Jan 8 2011, 10:26 AM
detoxcowboy The best 4 wheel allighnment in So. Cal.; if you h... Jan 8 2011, 02:38 PM
detoxcowboy Yeah, it is the factory 'marathon blue', I... Jan 8 2011, 07:32 PM
falconfp2001 Took the car out today to get parts as I'm rep... Jan 8 2011, 11:40 PM
silver74insocal "if anyone lives close and can lend a hand wi... Jan 9 2011, 12:39 AM
falconfp2001 Let me tell you what I have gotten myself into.
1... Jan 9 2011, 01:24 AM
detoxcowboy :DRUNK: Frank, Your alright,
Where do I start... Jan 9 2011, 09:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 09:39 PM |
