> six conversion engine compartment heater hose, size? engine tin hole size? coupler in tin?
jim912928
post Jan 8 2011, 01:55 PM
I am putting heat in my six conversion. I know where I'm placing my fan, but what I don't know is what size and location should I cut the holes in the engine tin? Did the factory or the 911 setups use a coupler to connect the hose from topside of the tin to underneath? What have others done? Pics of your setups?
Engine: 3.2l, have the later 914 blower motor connector that branches at the fan into two outlets, heat exchangers are GHL SS, using my 914-4 flapper boxes
jim912928
post Jan 8 2011, 07:59 PM
I'm either going to keep the 3.2l blower (if I shave the top of the fan housing it will just clear the engine lide) or use the backdated fan shroud pieces. Either way i'm going to be cutting holes on both sides of the engine tin like the factory did. Does anybody have measurements on where the holes go as the factory did them and what size they are?
Also, if I backdate I've been told that the driver side is a direct bolt on but the driver side on a 3.2+ has to be modified or find a turbo piece to fit around the distributer?
post Jan 8 2011, 08:33 PM
914-6 GT in waiting
QUOTE(jim912928 @ Jan 8 2011, 08:59 PM) *
I have some stock 6 side pieces. I'll take some pics and measure. I also bought the backdated heater ducts. Guys on pelican suggest using a hammer on the metal duct to make clearance around the distributor if you need it.
not my engine in pics
- Lo-Fi Version Time is now: 12th March 2026 - 09:55 PM
