| jim912928 |
Jan 8 2011, 01:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I am putting heat in my six conversion. I know where I'm placing my fan, but what I don't know is what size and location should I cut the holes in the engine tin? Did the factory or the 911 setups use a coupler to connect the hose from topside of the tin to underneath? What have others done? Pics of your setups?
Engine: 3.2l, have the later 914 blower motor connector that branches at the fan into two outlets, heat exchangers are GHL SS, using my 914-4 flapper boxes |
| moparrob |
Jan 8 2011, 11:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Jim,
I am deleting the heaters on my '79 3.0 engine conversion, so I have an extra set of the original sheet metal pieces pictured in the post above. I will need to replace them with block off plates, which I have found and are going to cost me $125.00. plus shipping. I'll sell you my original pieces for $110.00 shipped to you if you are interested. They are in very good condition. Let me know. Rob robrose426@att.net |
jim912928 six conversion engine compartment heater hose Jan 8 2011, 01:55 PM
dr914@autoatlanta.com I would say that with the 911 impeller fan you wou... Jan 8 2011, 02:18 PM
Steve
I would say that with the 911 impeller fan you wo... Jan 8 2011, 02:23 PM
Steve I'm running a 3.2 with factory heat exchangers... Jan 8 2011, 02:19 PM
Steve Here's the other side.
shoguneagle Jim,
I believe the 911 used a duct from the fan l... Jan 8 2011, 02:37 PM
Steve I originally had this setup with the stock hose, b... Jan 8 2011, 02:43 PM
jim912928 I'm either going to keep the 3.2l blower (if I... Jan 8 2011, 07:59 PM
I'm either going to keep the 3.2l blower (if ... Jan 8 2011, 08:33 PM
Steve Sorry Jim, i am using factory 914-6 sheet metal an... Jan 8 2011, 08:09 PM
jim912928 excellent pics! And thanks in advance for tak... Jan 8 2011, 08:36 PM
mepstein pic Jan 8 2011, 08:51 PM
mepstein hole is 2 5/8. I'm guessing hose is about 2 1/... Jan 8 2011, 08:53 PM
mepstein heater backdate tin. paid $110 on pelican cla... Jan 8 2011, 09:26 PM
heater backdate tin. paid $110 on pelican cl... Jan 12 2011, 11:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 09:55 PM |
