| geniusanthony |
Jan 8 2011, 07:28 PM
Its a brand new "Chrome-sicle" ![]() ![]() ![]() Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
While my engine was out for clean up, I decided to take action on the clutch components that I knew were due or questionable. I have recently (in the past year) done the clutch cable and even when it was new I still had the adjuster turned nearly all the way in.
Yesterday I replaced the Clutch cable arm bushing, 901-423-343-00, the old one was nearly worn through. When I reinstall I am using a new Clutch cable end 911-423-205-03, this is the upgraded metal one instead of plastic. The friction disk is new but not noticeably thicker than the old one. There was probably an eighth of an inch on either side of the rivets. With the trans installed onto the engine If I pull back on the clutch arm it is nearly even with the end of the bottom stud coming off the back of the case, so there is still a half inch maybe of travel before you feel the pressure plate. So the question is does that sound about right or should I do something else while I am in there. |
| Dr Evil |
Jan 8 2011, 11:37 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
For a more lengthy and in-depth explanation of this, click on the 31 pages link below. I address it (IMG:style_emoticons/default/smile.gif)
geniusanthony Clutch arm play Jan 8 2011, 07:28 PM
r_towle Measure your flywheel to see if it has been ground... Jan 8 2011, 09:57 PM
geniusanthony Great explanation, i'll check it out tomorrow ... Jan 8 2011, 10:09 PM
r_towle oh,
Clutch release forks have been known to get be... Jan 8 2011, 10:15 PM
geniusanthony http://www.pelicanparts.com/techarticles/9...ch_re... Jan 8 2011, 10:40 PM
geniusanthony It seems as though I am good with a half inch of p... Jan 8 2011, 10:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 08:26 AM |
