| 914 shifter |
Jan 7 2011, 02:28 PM
airhead ![]() ![]() Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
if its close to, or above freezing i was thinking of starting up 70 1.7 d jet once in a while, and letting it idle/warm up for a few minutes.any opinions / facts on this.plus i have a cold start issue i would like to address.on start up the car idles for about a minute then i have to keep it running till she warms up about 10-15 min. of driving.once warm she idles nicely at about 850 rpm. (IMG:style_emoticons/default/chowtime.gif) (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/happy11.gif)
| VaccaRabite |
Jan 8 2011, 10:29 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,856 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Eh. I put Stabil in the tank, went for a spin and then parked it and siphoned all the gas out of the tank and burned it up in my daily. In the spring I'll probably have to clean my idle jets and pull the stacks and clean them. But other then that, it won't see the world outside my garage until spring.
Zach |
| r_towle |
Jan 9 2011, 06:34 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Eh. I put Stabil in the tank, went for a spin and then parked it and siphoned all the gas out of the tank and burned it up in my daily. In the spring I'll probably have to clean my idle jets and pull the stacks and clean them. But other then that, it won't see the world outside my garage until spring. Zach Zach, Best luck I have had was to run out of gas.. This sucks all the fuel out of the bowls in the carbs and gets them dry. Otherwise you start building up a bunch of laquer in the carb bowls...might take two or three years...but it eventually requires full rebuilds. the 356 has a nice shutoff valve...so I just get it warm turn off the fuel and wait a few minutes till it stalls...all done for the season. Rich |
914 shifter winter start up Jan 7 2011, 02:28 PM
sean_v8_914 full opersating temp, raise idle over 2k. must get... Jan 7 2011, 02:32 PM
flipb I've had the same question, and the answers se... Jan 7 2011, 02:33 PM
Cupomeat Well, this is my opinion on this based on understa... Jan 7 2011, 02:38 PM
dr914@autoatlanta.com There could be several problems. The aux air valv... Jan 7 2011, 02:55 PM
zx-niner Move to California (or Arizona or Southern Nevada)... Jan 8 2011, 11:34 AM
detoxcowboy
if its close to, or above freezing i was thinking... Jan 8 2011, 12:09 PM
Rand If you are going to start it, then drive it. Don... Jan 8 2011, 12:30 PM
Ian Stott If you start it up make sure you run it long enoug... Jan 9 2011, 08:08 AM
9146986 Getting the engine hot enough to evaporate any bui... Jan 9 2011, 03:02 PM
sean_v8_914 yes, stabil fuel stabilizer will prevent resin for... Jan 10 2011, 12:35 PM
r_towle moody today, arent we.
Yes I use stabilizer and n... Jan 10 2011, 08:14 PM
Matt Romanowski I'm in the Stabil camp. Add it, top off the ta... Jan 10 2011, 08:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 08:28 AM |
