> Welding question
r_towle
post Jan 9 2011, 06:27 PM
Custom Member
In an effort to learn how the more experienced and professional welders handle this, I have a question.
I will be adding 1/8 inch steel to a 356 chassis.
This will be a structural element and will be under some stress.
It is part of the rear suspension.
What is the best welding technique to use to weld 1/8 inch steel angle iron to a standard 19 gauge 50 year old chassis and ensure that the welds hold...they do what they are supposed to and I dont spend the entire time blowing through the 19 gauge steel?
I will be getting the piece of steel from a steel yard, basically a 4 inch by 4 inch angle iron piece welded along the ends, and along the length as needed.
I have a mig welder and a oxy/ace torch.
I dont have a tig, and I wont outsource this...so I am looking for techniques to use what I have.
Rich
IronHillRestorations
post Jan 9 2011, 06:40 PM
I. I. R. C.
I'm guessing you typo'd and meant to say you don't have a tig?
Practicing with the same two gauges of metal is the best thing you can do. Be sure to record the settings you use on your welder, and do a little practice every time you go to weld.
- Lo-Fi Version Time is now: 1st May 2026 - 02:31 PM
