> Welding question
r_towle
post Jan 9 2011, 06:27 PM
Custom Member
In an effort to learn how the more experienced and professional welders handle this, I have a question.
I will be adding 1/8 inch steel to a 356 chassis.
This will be a structural element and will be under some stress.
It is part of the rear suspension.
What is the best welding technique to use to weld 1/8 inch steel angle iron to a standard 19 gauge 50 year old chassis and ensure that the welds hold...they do what they are supposed to and I dont spend the entire time blowing through the 19 gauge steel?
I will be getting the piece of steel from a steel yard, basically a 4 inch by 4 inch angle iron piece welded along the ends, and along the length as needed.
I have a mig welder and a oxy/ace torch.
I dont have a tig, and I wont outsource this...so I am looking for techniques to use what I have.
Rich
scotty b
post Jan 9 2011, 06:42 PM
rust free you say ?
Mig it. Start the weld on the 1/8 and melt that onto the sheet. It takes a few tries to get the hang, but if you watch the puddle you will pick it up quickly. Also do several tacks spaced apart to get the strength there before trying to run a bead like this. That will reduce the chances of blow through and warp
r_towle
post Jan 9 2011, 06:55 PM
Custom Member
QUOTE(scotty b @ Jan 9 2011, 07:42 PM) *
cool, that is what I figured...not sure about the settings but I will mess around with some scrap first.
Rich
rick 918-S
post Jan 9 2011, 07:36 PM
Hey nice rack! -Celette
QUOTE(r_towle @ Jan 9 2011, 06:55 PM) *
Rich
Email me photos of what your doing if you want. Maybe I can help. I have never found the need to add heavy metal to sheet steel. You end up relying on the weld metal along the edge of the pieces for strength. Most of the patch work I've seen like this are weaker than if it was done with 19 ga to 19 ga. If you need strength (tosional or longitudinal) use 18 ga. and form it with bends or shapes like the factory did. Otherwise use 16 ga. will be fine(1/16") and use a plug welding method. This will span the overlap on the 19ga and get a better strength.
- Lo-Fi Version Time is now: 1st May 2026 - 02:32 PM
