tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
I am going to corner blance my 914 in the next week or so and I am looking for any tips that my help.
I picked up a set of Mad Racing scales, a Longacre caster/camber gauge and toe plates off of CL for $200. After I purchased said items I could not find a lot of info on the Mad Racing scales: ![]() I did find that folks don't like these scales especially when compared to the Longacre digital scales. It also seems that there is a question about repeatability and accuracy with this type of scale. But they are what I have. So, I would appreciate any advice on using these scales as well as the camber/caster gauge & toe plates. My suspension set up is: Elephant Poly Bronze x 4 GPR front bar Stock torsion Upper front monoballs 150lb Eibach springs w/ ground control Bilstein shocks x 4 Turbo tie rods & bump steer. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,258 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I am going to corner blance my 914 in the next week or so and I am looking for any tips that my help. You're looking for 50/50 cross weight and close to that in front/rear balance. - Break tie rods lose in the front and the trailing arms bolts in the rear if you are planning to do a full alignment. - 1/2 to 3/4 tank of gas - Full drivers weight in the drivers seat - Disconnect any swaybars - Roll the car on the scales - Set ride-height roughly where you want it - Fine tune height using the scales until you are happy with the cross weights - Lock in steering wheel in center position (two wooden poles cut to length work great for this) - Set camber (and caster if needed) - Set toe - Tighten the tie rods and trailing arm bolts - Reconnect the sway bars - Go for a drive I think that's it ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 19th July 2025 - 04:46 PM |
