> Corner balance, any tips?
tradisrad
post Jan 10 2011, 03:22 PM
I am going to corner blance my 914 in the next week or so and I am looking for any tips that my help.
I picked up a set of Mad Racing scales, a Longacre caster/camber gauge and toe plates off of CL for $200. After I purchased said items I could not find a lot of info on the Mad Racing scales:
I did find that folks don't like these scales especially when compared to the Longacre digital scales. It also seems that there is a question about repeatability and accuracy with this type of scale. But they are what I have.
So, I would appreciate any advice on using these scales as well as the camber/caster gauge & toe plates.
My suspension set up is:
Elephant Poly Bronze x 4
GPR front bar
Stock torsion
Upper front monoballs
150lb Eibach springs w/ ground control
Bilstein shocks x 4
Turbo tie rods & bump steer.
tradisrad
post Jan 10 2011, 04:48 PM
Andy, Thanks. I hope it is as easy as you make it sound.
I am not sure if I am going to do a full alignment. Rich at HPH said that my alignment should not be thrown off too much. I will check camber/caster & toe before and after to see what changed.
post Jan 10 2011, 04:51 PM
Resident German
QUOTE(tradisrad @ Jan 10 2011, 02:48 PM) *
I wouldn't do without an alignment after a corner balance ... (IMG:style_emoticons/default/shades.gif)
tradisrad   Corner balance   Jan 10 2011, 03:22 PM
SirAndy   I am going to corner blance my 914 in the next wee...   Jan 10 2011, 03:37 PM
tradisrad   Andy, Thanks. I hope it is as easy as you make it ...   Jan 10 2011, 04:48 PM
SirAndy   Rich at HPH said that my alignment should not be t...   Jan 10 2011, 04:51 PM
jjackson   In our experience-corner balancing after alignment...   Jan 10 2011, 05:05 PM
tradisrad   Should I bring my car back to the specs that it is...   Jan 10 2011, 05:24 PM
jjackson   Should I bring my car back to the specs that it i...   Jan 10 2011, 05:32 PM
strawman   I used a similar "fulcrum-based" lever s...   Jan 10 2011, 07:33 PM
r_towle   If you dont have rear threaded perches, you can on...   Jan 10 2011, 07:44 PM
tradisrad   I spent some time last weekend playing with the co...   Jan 18 2011, 01:18 PM
SirAndy   1. is it possible that my car is not square from t...   Jan 18 2011, 02:21 PM
Borderline   There's another theory of corner balance that ...   Jan 18 2011, 08:11 PM
tradisrad   after a few weeks time and sorting out some suspen...   Feb 19 2011, 12:49 PM
sean_v8_914   did you have slider plates under each wheel?   Feb 19 2011, 01:05 PM
tradisrad   slider plates? I have a set of 4 scales, arms, bal...   Feb 19 2011, 01:21 PM
McMark   If you jack up the car, you need to roll the car t...   Feb 19 2011, 01:53 PM
tradisrad   Thanks Mark. The lever arms for the scales do have...   Feb 19 2011, 02:17 PM
sean_v8_914   square metal plate about 15 x 15 on top of similar...   Feb 19 2011, 03:12 PM
sean_v8_914   rubber bushings and this sweep conspire against go...   Feb 19 2011, 03:19 PM
tradisrad   i've got elephant poly bronze on all 4 corners...   Feb 19 2011, 07:09 PM
PRS914-6   The tires and wheels need to "float" or ...   Feb 19 2011, 09:09 PM
- Lo-Fi Version Time is now: 19th July 2025 - 04:46 PM
