> Best way to get car on rotisserre
corpselaurel
post Jun 17 2004, 11:02 AM
I am wondering what all of you who don't have a lift do.
Gudhjem
post Jan 10 2011, 06:01 PM
A follow-up:
I end up using a hoist attached as Chris described - at the seat adjuster brackets. A hoist made everything easy even as a solo operation. No drama, just operate the crane with one had and balance the almost-balanced load with the other. The weak point is probably the brackets themselves. As Chris said, I wouldn't use those as lift points if they were rusty or otherwise suspect, and would only do it with a pretty much stripped tub.
As for the rotisserie, it seems very stable, even without a support between the 2 ends. It could be dangerous if one end caught while rolling though, or at least could end up tweaking the bumper mounts or even the frame. I don't plan to move it much, but it's easy enough to clamp or bolt on a connector piece if I want to, and moving with 2 people is easy enough.
Overall I'm very happy with the rotisserie. I think if I had it to do over again, I might either go with 2-legged stands (like Zach's) to make loading without a hoist easier and make storage a bit easier, or I would have included a hight adjustment. It wouldn't have been that hard to make a piece that slides up the stand using a come-along, which would have avoided all the lifting issues.
Here's a couple pics of the car on the spit:
Thanks for all the help (IMG:style_emoticons/default/beerchug.gif)
--Steve
corpselaurel   Best way to get car on rotisserre   Jun 17 2004, 11:02 AM
itsa914   I have never done it myself, but from what I read ...   Jun 17 2004, 11:36 AM
maf914   I was thinking that if you had a big tree limb ove...   Jun 17 2004, 11:55 AM
william harris   Here's how I did it. For starters, my car was...   Jun 17 2004, 12:34 PM
corpselaurel   I was thinking of using 4 tractor jacks (they go u...   Jun 17 2004, 01:21 PM
thesey914   Someone on this board used a fork-lift truck from ...   Jun 17 2004, 03:23 PM
Carrera916   Another possibility is to use the engine "cherry p...   Jun 17 2004, 03:30 PM
Racer Chris   It is easy if you have an engine hoist. Put hooks ...   Jun 17 2004, 03:41 PM
Gudhjem   "Put hooks (I bent 2 long 5/16 bolts) into th...   Jan 3 2011, 07:43 PM
r_towle   engine hoist, right off the ground. Bolt on the ba...   Jan 3 2011, 08:09 PM
Gudhjem   engine hoist, right off the ground. Bolt on the b...   Jan 3 2011, 11:21 PM
Vacca Rabite   Hmmm, mine both have three wheels, and so the c...   Jan 4 2011, 07:22 AM
Richard Casto   For the sake of you and anyone working with you, ...   Jan 4 2011, 08:18 AM
stugray   "Hmmm, mine both have three wheels, and so th...   Jan 4 2011, 06:34 AM
Gudhjem   Going out on a limb here, I'm guessing that Ri...   Jan 4 2011, 05:59 PM
Racer Chris   I'd like to go with Racer Chris's method ...   Jan 4 2011, 09:04 PM
stugray   "Going out on a limb here, I'm guessing t...   Jan 4 2011, 09:56 PM
r_towle   ok, IC the difference in designs. I personally lik...   Jan 4 2011, 10:45 PM
Gudhjem   A follow-up: I end up using a hoist attached as C...   Jan 10 2011, 06:01 PM
- Lo-Fi Version Time is now: 14th April 2026 - 06:19 PM
