Lincoln pack100 Welding?, What wire/settings works best with our cars? |
Jeffs9146 |
Jan 10 2011, 03:55 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Lennies914 and I are welding up some AC holes the PO put all over my car and we are having a problem with blow through. We currently have it set at A 1.4 with flux core .035 #2 wire!
Lennie is almost to Harbor freight and wants to know what is the best used with our cars?? Thanks for any quick replies!! (IMG:style_emoticons/default/piratenanner.gif) |
strawman |
Jan 10 2011, 07:14 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
I have found ESAB Easy-Grind 0.23" wire and 75/25 gas to be the best. As mentioned above, the metal has to be uber-clean, too. Can't say which settings, since I don't have the same MIG welder that you have...
Where ever possible, also put a heat sink behind the weld. HF has a brass spoon that works pretty well. And weld in short bursts to keep from warping the metal and to avoid heat gain that can lead to blow-through. Geoff |
Lo-Fi Version | Time is now: 7th June 2024 - 11:26 AM |
