| malaga_red75 |
Jan 11 2011, 10:13 PM
'74 2.5L N/A Subie ![]() ![]() Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
I need to get tires for my 914 that has the american revolution 'empi style' wheel.
what are you guys running? this will be summer performance tires only. im looking for dedicated street tires. thanks in advance -peter |
| Root_Werks |
Jan 12 2011, 10:38 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,862 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
It's all about what you want when you drive. 100hp air-cooled motors don't like wide tires and they will slow your 914 down. Low profile tires will throw the speedo even further off than it came from the factory. 195/50/15's are a common size I see on 914's. But the RPM's are higher while cruising as well as the speedo saying 75mph when your only going 60mph. 195/65/15's won't see as nice response when you change direction (Like track/course driving), but would be nicer to your ears when taking long trips and the speedo would be closer to accurate.
Others have said, you're a little limited since you have the VW offset rims. A 195 will be tight even with rolling the rear fenders a bit. I run 185/65/15's because I drive my 914 a lot. Fuel mileage and comfort are a big deal to me. I like to hear the radio and not have my ear drums hurt after a long drive. Even with those tires, my speedo is still 8% off. So it's kinda up to you, you're style and what you'll use the 914 for. That's my 2 cents. (IMG:style_emoticons/default/smile.gif) |
malaga_red75 Tires for stock wheels Jan 11 2011, 10:13 PM
DanT On the 8 spoke Empi knock offs they have a bigger ... Jan 11 2011, 10:19 PM
BMXerror
I am running Dunlop Direzza Star Spec Z1s in 205x... Jan 12 2011, 10:57 AM
detoxcowboy The tire shop will let you try for fit,do it both ... Jan 11 2011, 10:30 PM
DanT I had a set of the Empis on my last car and it had... Jan 11 2011, 10:39 PM
malaga_red75 so it sounds like without a pulled fender... it wo... Jan 11 2011, 11:54 PM
DanT yes unless you find some stock Fuchs....with the p... Jan 12 2011, 12:02 AM
malaga_red75 I guess I will just start with 195x60 and do a tes... Jan 12 2011, 01:56 PM
malaga_red75 also, how did my post get duplicated?? Jan 12 2011, 01:56 PM
Slider did you go with the 195-60's ? what are your t... Mar 4 2011, 06:58 PM
malaga_red75
did you go with the 195-60's ? what are your ... Mar 27 2011, 04:37 PM
rdauenhauer Any one have any success fitting a 215/60 on stock... Mar 27 2011, 02:22 PM
Mike914
Any one have any success fitting a 215/60 on stoc... Mar 27 2011, 08:36 PM
DanT Sorry Rich, only have mounted 205x50s and 205x60s ... Mar 27 2011, 04:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 12:39 PM |
