scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
(IMG:style_emoticons/default/idea.gif) I'm just curious what you CW's think about replacing the plastic lines with steel on a restoration ?Granted they are not original, I am assuming NONE of you would actually run the 35+ year old lines and would at the very least replace them with new plastic lines. That then begs the question, If you are replacing the lines, from a CW standpoint are steel lines still grounds for a beating ? Think about the safety of the car too
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/biggrin.gif) |
Pat Garvey |
Do I or don't I...........? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States ![]() |
(IMG:style_emoticons/default/idea.gif) I'm just curious what you CW's think about replacing the plastic lines with steel on a restoration ?Granted they are not original, I am assuming NONE of you would actually run the 35+ year old lines and would at the very least replace them with new plastic lines. That then begs the question, If you are replacing the lines, from a CW standpoint are steel lines still grounds for a beating ? Think about the safety of the car too (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/biggrin.gif) I have mixed opinions on the stainless replacements. Are they a better choice? Probably, because they'll have a longer potential life. Are they an unoriginal piece? Yeppir! Do they show, so's a CW judge would spot them? Yeppir, but it would yake a "competent" judge, and they are few. I'm willing to take a chance on my 39 year old plastic lines because they have never weeped, cracked or failed. Should I ever become suspect of them, I'll replace with same. I enjoy the feel of originality. It has worked for nearly 40 years. If I have to replace with plastic, and they only last another 40 years.....I'll be 104 years old and leaking more than they. Oh yeah, I'll be here. Just to keep you youngsters in line. Pat |
Jasfsmith |
Senior Member ![]() ![]() ![]() Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States ![]() ![]() |
I have mixed opinions on the stainless replacements. Are they a better choice? Probably, because they'll have a longer potential life. Are they an unoriginal piece? Yeppir! Do they show, so's a CW judge would spot them? Yeppir, but it would yake a "competent" judge, and they are few. I'm willing to take a chance on my 39 year old plastic lines because they have never weeped, cracked or failed. Should I ever become suspect of them, I'll replace with same. I enjoy the feel of originality. It has worked for nearly 40 years. If I have to replace with plastic, and they only last another 40 years.....I'll be 104 years old and leaking more than they. Oh yeah, I'll be here. Just to keep you youngsters in line. Pat You should expect to be dinged for using the stainless replacements. Both my 914's have oriiginal tunnel fuel lines and the 914-4 has OEM replacement (of 1980's vintage). I've never see a plastic line in the tunnel leak from age alone, Usually the result of some other repair which resulted in their damage. BTW I have a set of Chris's SS lines to put into my 914-6, the next time I have a chance. If I ever run the Concour cicuit again, I'd expect to be dinged.... |
Lo-Fi Version | Time is now: 15th June 2024 - 07:47 PM |
