| watsonrx13 |
Jan 17 2011, 06:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Since I've rebuilt my '74 2.0l FI engine I've had problems with the car not idling. After it warms up it dies. I've set the timing to 27 and the dwell is at 46. I tried adjusting the ECU knob and the air idle screw but neither appear to have any effect on the idle. When I adjust the knob I can feel it click. I counted 21 total clicks. The engine runs great above idle. The injectors have been rebuilt, new AA vacuum hoses replaced, all gaskets are new.
Can the ECU be taken apart and cleaned? Does anyone have a pic of the ECU opened up showing the knob area? Any recommendations on how to fix the idle problem I'm having? -- Rob |
| watsonrx13 |
Jan 17 2011, 11:57 AM
So if I read Brad website correctly I need a 0 280 130 003 head temp sensor. Is the number stamped on the sensor? What is the Porsche part number, I'd like to order this thru my local Porsche dealer.
BTW I did add the spacer that Brad built should I remove this first then test again? -- Rob |
| Krieger |
Jan 17 2011, 12:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,890 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
So if I read Brad website correctly I need a 0 280 130 003 head temp sensor. Is the number stamped on the sensor? What is the Porsche part number, I'd like to order this thru my local Porsche dealer. BTW I did add the spacer that Brad built should I remove this first then test again? -- Rob The spacer if installed correctly will not be a problem. Test your sensor first, before you replace it. I think the spec is 2000 ohms when cold. O ohms hot. Hook your multimeter up and jiggle the wire and see what happens. |
watsonrx13 No idle - '74 2.0l FI Jan 17 2011, 06:55 AM
gasman First check that the AAR is fully closed when warm... Jan 17 2011, 10:11 AM
r_towle I would agree that something else it wrong.
The kn... Jan 17 2011, 10:16 AM
Jeffs9146
Check your CHTS (Cylinder Head Temp Sensor) This... Jan 17 2011, 10:20 AM
jsayre914 Vacume leak?? Check all the hoses are tight and ma... Jan 17 2011, 11:33 AM
messix oil fill cap not tight? Jan 17 2011, 01:15 PM
r_towle Here is how I go about this...and it works.
Unplug... Jan 17 2011, 02:24 PM
SLITS Make sure the knob is in the middle of the range .... Jan 17 2011, 08:26 PM
detoxcowboy
Since I've rebuilt my '74 2.0l FI engine ... Jan 18 2011, 12:23 AM
detoxcowboy I also have a 74 2.0, :agree: there is another pr... Jan 18 2011, 11:07 AM
watsonrx13 I was finally able to work on the car this weekend... Jan 31 2011, 05:23 PM
sfrenck
I was finally able to work on the car this weeken... Jan 31 2011, 06:12 PM
Spoke
I took the car out for a quick drive and didn... Feb 1 2011, 10:55 AM
detoxcowboy
I took the car out for a quick drive and didn... Feb 1 2011, 11:33 AM
watsonrx13 more pics..
Here's how I tested the AAR..... Jan 31 2011, 05:24 PM
Jeffs9146 I still vote for CHTS!!!! Jan 31 2011, 05:51 PM
detoxcowboy CHT Value and issue,
Function: Senses engine tem... Jan 31 2011, 06:19 PM
watsonrx13 Thanks guys. I also believe it appears to be a pro... Jan 31 2011, 07:19 PM
Jeffs9146
It is not hard but be very carefull not to cross... Jan 31 2011, 07:43 PM
underthetire
It is not hard but be very carefull not to cros... Feb 1 2011, 10:04 AM
brenz
It is not hard but be very carefull not to cros... Feb 1 2011, 11:34 AM
Spoke One simple test you can do to make sure your CHT i... Feb 1 2011, 05:58 AM
detoxcowboy 74 2.0 does not use the "missing" advanc... Feb 1 2011, 08:11 AM
detoxcowboy From the link I posted further up this post..
Th... Feb 1 2011, 11:31 AM
watsonrx13 OK guys the engine started right up and is now idl... Feb 1 2011, 04:46 PM
Jeffs9146 :first: :first: :first: :first:
I win!... Feb 1 2011, 07:02 PM
detoxcowboy :hard: done, It's over! Congrats! CHT ... Feb 1 2011, 07:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 10:15 PM |
