> POLL : 911 Steering Column, Your opinions please
911 Steering Column
Which 911 steering column to use?
Early 1970-1973 straight arm stalk type (similar to 914-6) [ 28 ] ** [84.85%]
Later 1976-1989 bent arm stalk type [ 5 ] ** [15.15%]
Total Votes: 33
Guests cannot vote
John
post Jan 13 2011, 09:54 PM
member? what's a member?
I will convert to a 911 steering column. I have parts for both (with the exception of an early horn contact), and am debating in my head of which one to use.
If I use the early parts, it would "look" more period correct, but the switches just aren't as nice and seem to be harder to come by. If I use the later model 911 parts, I can easily get replacements, but it just won't look the same.
I'm a little biased toward using the early parts, but I'm still "on the fence" when it comes to deciding.
Thanks for your input.
John
post Jan 21 2011, 06:01 PM
Dash mod....
post Jan 24 2011, 12:00 PM
Resident German
QUOTE(John @ Jan 21 2011, 04:01 PM) *
Dash mod....
(IMG:style_emoticons/default/thumb3d.gif)
I used the attachment piece from a 911 dash and left some metal around it to mate it to the 914 dash.
It's not a perfect fit as the angle is off just a bit compared to the 914 dash sub-frame.
Yours looks nicer ... (IMG:style_emoticons/default/biggrin.gif)
John   POLL : 911 Steering Column   Jan 13 2011, 09:54 PM
SirAndy   I will convert to a 911 steering column. I have ...   Jan 13 2011, 10:05 PM
914Sixer   I like the early.   Jan 14 2011, 06:52 AM
dflesburg   I used the early one. in my car.   Jan 14 2011, 08:22 AM
John   Hmm. 10 to 1 so far. I didn't realize it wou...   Jan 15 2011, 09:29 PM
John   late model early early   Jan 16 2011, 07:23 PM
John   Dash mod....   Jan 21 2011, 06:01 PM
SirAndy   Dash mod.... :thumbsup: I used the attachment pie...   Jan 24 2011, 12:00 PM
John   Dash mod.... :thumbsup: I used the attachment pi...   Jan 25 2011, 08:21 PM
John   I re-did the mount plate lowering it down a bit. ...   Jan 23 2011, 06:24 PM
SirAndy   Here's mine mounted, like i said, yours looks ...   Jan 25 2011, 09:13 PM
John   Must be a few different versions of early switches...   Jan 25 2011, 09:38 PM
SirAndy   Must be a few different versions of early switche...   Jan 25 2011, 09:56 PM
John   So Andy, since you have done this, I have a questi...   Jan 25 2011, 10:06 PM
SirAndy   My question is: Did you eliminate the headlight di...   Jan 28 2011, 01:16 PM
John   My question is: Did you eliminate the headlight d...   Jan 28 2011, 08:23 PM
John   Minor setback. I made my bracket fit my 71 unit b...   Feb 5 2011, 08:57 PM
SirAndy   Who knew the bolt patterns changed between years? ...   Feb 6 2011, 01:20 AM
John   Setbacks. Oh well, it's just cutting welding ...   Feb 6 2011, 04:33 PM
SirAndy   I'm moving the fog light switch to the other s...   Feb 6 2011, 05:01 PM
John   Zinc plated and treated with yellow chromate.   Feb 6 2011, 09:47 PM
dflesburg   very pretty. I thought I told you that early cars...   Feb 7 2011, 07:51 AM
John   very pretty. I thought I told you that early car...   Feb 7 2011, 12:19 PM
John   A little more progress and it lives! I starte...   Mar 12 2011, 11:23 PM
jaxdream   That cutout may be for the old style dash mounted ...   Mar 13 2011, 09:08 AM
SirAndy   That cutout may be for the old style dash mounted ...   Mar 13 2011, 05:18 PM
type47fan   Headlight cleaner/washer option "spray contro...   Mar 13 2011, 12:04 PM
John   I believe that Wayne nailed it. Headlight washers...   Mar 13 2011, 08:49 PM
John   Getting closer...... New vinyl Installed dash ...   Mar 20 2011, 09:20 PM
dflesburg   Great Job, now all you need is the early lower das...   Mar 21 2011, 06:44 AM
John   Great Job, now all you need is the early lower da...   Mar 21 2011, 09:28 PM
dflesburg   cool by me.   Mar 22 2011, 09:46 AM
John   After getting everything back together, I did more...   Mar 23 2011, 07:14 PM
John   Wrapped it up today.   Mar 26 2011, 08:13 PM
John   Here is a tool I made and some screws I yellow chr...   Mar 26 2011, 08:17 PM
jaxdream   What is the tool for ???? Jack / Jaxdream   Mar 27 2011, 08:42 AM
John   What is the tool for ???? Jack / Jaxdream I g...   Mar 27 2011, 08:53 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:22 PM
