> POLL : 911 Steering Column, Your opinions please
911 Steering Column
Which 911 steering column to use?
Early 1970-1973 straight arm stalk type (similar to 914-6) [ 28 ] ** [84.85%]
Later 1976-1989 bent arm stalk type [ 5 ] ** [15.15%]
Total Votes: 33
Guests cannot vote
John
post Jan 13 2011, 09:54 PM
member? what's a member?
I will convert to a 911 steering column. I have parts for both (with the exception of an early horn contact), and am debating in my head of which one to use.
If I use the early parts, it would "look" more period correct, but the switches just aren't as nice and seem to be harder to come by. If I use the later model 911 parts, I can easily get replacements, but it just won't look the same.
I'm a little biased toward using the early parts, but I'm still "on the fence" when it comes to deciding.
Thanks for your input.
John
post Jan 25 2011, 10:06 PM
So Andy, since you have done this, I have a question that I have been debating with myself for a while.
Let me explain. The 4-cyl stalk had a momentary contact to "toggle" the dimmer relay to switch between high beams and low beams. The 911 stalk has both a momentary contact as well as a two position switch. As it is wired in a 911, the two positions are for high and low beams. The momentary contact allows the headlights to flash low beams. Since the 914 headlights are hidden, it makes no sense to be able to flash the low beams.
My question is: Did you eliminate the headlight dimmer relay and utilize the two position contact on the stalk or did you utilize the momentary contact and wire that to the headlight dimmer relay? I know yours was once a 4-cyl steering column before thieves tore it all up.
I'm strongly considering only using the momentary contact to drive the dimmer relay. I already have a fog light flash relay that will continue to operate if I do this. It may not work exactly like it should, but it would work.
post Jan 28 2011, 01:16 PM
Resident German
QUOTE(John @ Jan 25 2011, 08:06 PM) *
I kept the relay and used the momentary contact to switch the relay, just like on the /4 column.
I didn't feel like redoing any of that circuit and was pleased to find the trigger option on the 911 column.
John   POLL : 911 Steering Column   Jan 13 2011, 09:54 PM
SirAndy   I will convert to a 911 steering column. I have ...   Jan 13 2011, 10:05 PM
914Sixer   I like the early.   Jan 14 2011, 06:52 AM
dflesburg   I used the early one. in my car.   Jan 14 2011, 08:22 AM
John   Hmm. 10 to 1 so far. I didn't realize it wou...   Jan 15 2011, 09:29 PM
John   late model early early   Jan 16 2011, 07:23 PM
John   Dash mod....   Jan 21 2011, 06:01 PM
SirAndy   Dash mod.... :thumbsup: I used the attachment pie...   Jan 24 2011, 12:00 PM
John   Dash mod.... :thumbsup: I used the attachment pi...   Jan 25 2011, 08:21 PM
John   I re-did the mount plate lowering it down a bit. ...   Jan 23 2011, 06:24 PM
SirAndy   Here's mine mounted, like i said, yours looks ...   Jan 25 2011, 09:13 PM
John   Must be a few different versions of early switches...   Jan 25 2011, 09:38 PM
SirAndy   Must be a few different versions of early switche...   Jan 25 2011, 09:56 PM
John   So Andy, since you have done this, I have a questi...   Jan 25 2011, 10:06 PM
SirAndy   My question is: Did you eliminate the headlight di...   Jan 28 2011, 01:16 PM
John   My question is: Did you eliminate the headlight d...   Jan 28 2011, 08:23 PM
John   Minor setback. I made my bracket fit my 71 unit b...   Feb 5 2011, 08:57 PM
SirAndy   Who knew the bolt patterns changed between years? ...   Feb 6 2011, 01:20 AM
John   Setbacks. Oh well, it's just cutting welding ...   Feb 6 2011, 04:33 PM
SirAndy   I'm moving the fog light switch to the other s...   Feb 6 2011, 05:01 PM
John   Zinc plated and treated with yellow chromate.   Feb 6 2011, 09:47 PM
dflesburg   very pretty. I thought I told you that early cars...   Feb 7 2011, 07:51 AM
John   very pretty. I thought I told you that early car...   Feb 7 2011, 12:19 PM
John   A little more progress and it lives! I starte...   Mar 12 2011, 11:23 PM
jaxdream   That cutout may be for the old style dash mounted ...   Mar 13 2011, 09:08 AM
SirAndy   That cutout may be for the old style dash mounted ...   Mar 13 2011, 05:18 PM
type47fan   Headlight cleaner/washer option "spray contro...   Mar 13 2011, 12:04 PM
John   I believe that Wayne nailed it. Headlight washers...   Mar 13 2011, 08:49 PM
John   Getting closer...... New vinyl Installed dash ...   Mar 20 2011, 09:20 PM
dflesburg   Great Job, now all you need is the early lower das...   Mar 21 2011, 06:44 AM
John   Great Job, now all you need is the early lower da...   Mar 21 2011, 09:28 PM
dflesburg   cool by me.   Mar 22 2011, 09:46 AM
John   After getting everything back together, I did more...   Mar 23 2011, 07:14 PM
John   Wrapped it up today.   Mar 26 2011, 08:13 PM
John   Here is a tool I made and some screws I yellow chr...   Mar 26 2011, 08:17 PM
jaxdream   What is the tool for ???? Jack / Jaxdream   Mar 27 2011, 08:42 AM
John   What is the tool for ???? Jack / Jaxdream I g...   Mar 27 2011, 08:53 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:14 PM
