| John |
Jan 13 2011, 09:54 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I will convert to a 911 steering column. I have parts for both (with the exception of an early horn contact), and am debating in my head of which one to use.
If I use the early parts, it would "look" more period correct, but the switches just aren't as nice and seem to be harder to come by. If I use the later model 911 parts, I can easily get replacements, but it just won't look the same. I'm a little biased toward using the early parts, but I'm still "on the fence" when it comes to deciding. Thanks for your input. |
| John |
Jan 25 2011, 10:06 PM
So Andy, since you have done this, I have a question that I have been debating with myself for a while.
Let me explain. The 4-cyl stalk had a momentary contact to "toggle" the dimmer relay to switch between high beams and low beams. The 911 stalk has both a momentary contact as well as a two position switch. As it is wired in a 911, the two positions are for high and low beams. The momentary contact allows the headlights to flash low beams. Since the 914 headlights are hidden, it makes no sense to be able to flash the low beams. My question is: Did you eliminate the headlight dimmer relay and utilize the two position contact on the stalk or did you utilize the momentary contact and wire that to the headlight dimmer relay? I know yours was once a 4-cyl steering column before thieves tore it all up. I'm strongly considering only using the momentary contact to drive the dimmer relay. I already have a fog light flash relay that will continue to operate if I do this. It may not work exactly like it should, but it would work. |
| SirAndy |
Jan 28 2011, 01:16 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My question is: Did you eliminate the headlight dimmer relay and utilize the two position contact on the stalk or did you utilize the momentary contact and wire that to the headlight dimmer relay? I kept the relay and used the momentary contact to switch the relay, just like on the /4 column. I didn't feel like redoing any of that circuit and was pleased to find the trigger option on the 911 column. (IMG:style_emoticons/default/driving.gif) |
| John |
Jan 28 2011, 08:23 PM
My question is: Did you eliminate the headlight dimmer relay and utilize the two position contact on the stalk or did you utilize the momentary contact and wire that to the headlight dimmer relay? I kept the relay and used the momentary contact to switch the relay, just like on the /4 column. I didn't feel like redoing any of that circuit and was pleased to find the trigger option on the 911 column. (IMG:style_emoticons/default/driving.gif) So I won't be alone. Got my new grips for my switches. The old ones were glued on. |
John POLL : 911 Steering Column Jan 13 2011, 09:54 PM
I will convert to a 911 steering column. I have ... Jan 13 2011, 10:05 PM
914Sixer I like the early. Jan 14 2011, 06:52 AM
dflesburg I used the early one. in my car.
Jan 14 2011, 08:22 AM
John Hmm.
10 to 1 so far. I didn't realize it wou... Jan 15 2011, 09:29 PM
John
late model
early
early Jan 16 2011, 07:23 PM
John Dash mod....
Jan 21 2011, 06:01 PM
SirAndy Dash mod....
:thumbsup:
I used the attachment pie... Jan 24 2011, 12:00 PM
John
Dash mod....
:thumbsup:
I used the attachment pi... Jan 25 2011, 08:21 PM
John I re-did the mount plate lowering it down a bit.
... Jan 23 2011, 06:24 PM
SirAndy Here's mine mounted, like i said, yours looks ... Jan 25 2011, 09:13 PM
John Must be a few different versions of early switches... Jan 25 2011, 09:38 PM
Must be a few different versions of early switche... Jan 25 2011, 09:56 PM
John Minor setback.
I made my bracket fit my 71 unit b... Feb 5 2011, 08:57 PM
SirAndy Who knew the bolt patterns changed between years?
... Feb 6 2011, 01:20 AM
John Setbacks.
Oh well, it's just cutting welding ... Feb 6 2011, 04:33 PM
SirAndy I'm moving the fog light switch to the other s... Feb 6 2011, 05:01 PM
John
Zinc plated and treated with yellow chromate. Feb 6 2011, 09:47 PM
dflesburg very pretty.
I thought I told you that early cars... Feb 7 2011, 07:51 AM
John
very pretty.
I thought I told you that early car... Feb 7 2011, 12:19 PM
John A little more progress and it lives! I starte... Mar 12 2011, 11:23 PM
jaxdream That cutout may be for the old style dash mounted ... Mar 13 2011, 09:08 AM
SirAndy That cutout may be for the old style dash mounted ... Mar 13 2011, 05:18 PM
type47fan Headlight cleaner/washer option "spray contro... Mar 13 2011, 12:04 PM
John I believe that Wayne nailed it. Headlight washers... Mar 13 2011, 08:49 PM
John Getting closer......
New vinyl
Installed dash ... Mar 20 2011, 09:20 PM
dflesburg Great Job, now all you need is the early lower das... Mar 21 2011, 06:44 AM
John
Great Job, now all you need is the early lower da... Mar 21 2011, 09:28 PM
dflesburg cool by me. Mar 22 2011, 09:46 AM
John After getting everything back together, I did more... Mar 23 2011, 07:14 PM
John Wrapped it up today.
Mar 26 2011, 08:13 PM
John Here is a tool I made and some screws I yellow chr... Mar 26 2011, 08:17 PM
jaxdream What is the tool for ????
Jack / Jaxdream Mar 27 2011, 08:42 AM
John
Jack / Jaxdream
I g... Mar 27 2011, 08:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:16 PM |
