| Black22 |
Jan 28 2011, 09:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Hey Fellas,
I'm looking for alternative senders to use with a Temp. Gauge that's part of the combo gas gauge. I know what the stock/correct sender type and placement is, but I don't want the hassle of the taco plate mounting and issues associated with that. Is there another sender that works with this gauge that is an easy and cheap alternative? I figure even if the gauge reads high or low, as long as it is functional and not pinned full on or off I can get an idea of where the "safe" range is. After all there aren't any temp. numbers on it. Anyone tried this Guage with a drain plug sender or anything else? (IMG:style_emoticons/default/confused24.gif) Just curious. Thanks, Mike |
| Black22 |
Jan 28 2011, 10:01 PM
Taco plates are not that plentiful or cheap. No to mention they have a tendency to leak and there is a reason they're called "taco" if not perfectly torqued.
I would need the taco plate, cover and sender. That's around $100 right? Not to mention draining all my oil (which I just changed with the good stuff). No thanks. Any other options? |
| detoxcowboy |
Jan 28 2011, 10:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Taco plates are not that plentiful or cheap. No to mention they have a tendency to leak and there is a reason they're called "taco" if not perfectly torqued. I would need the taco plate, cover and sender. That's around $100 right? Not to mention draining all my oil (which I just changed with the good stuff). No thanks. Any other options? $35-$75 negot. w/ everything seals bolts sender cover and plate, no taco sauce.. needs paper gasket maybe.. looks good cond. Sorry, I do not know if there is another super cheap way, maybe the dipstick temp. thngys i see time to time.. You do not have to toss your new oil, catch it clean, put it back in?? $75 negot.? http://www.thesamba.com/vw/classifieds/detail.php?id=1087476 I know this guy, his name is Allen, he will have the whole enchilada if you ask, restored cond. $35 http://cgi.ebay.com/ebaymotors/Porsche-914...sQ5fAccessories |
| Black22 |
Jan 28 2011, 10:17 PM
Taco plates are not that plentiful or cheap. No to mention they have a tendency to leak and there is a reason they're called "taco" if not perfectly torqued. I would need the taco plate, cover and sender. That's around $100 right? Not to mention draining all my oil (which I just changed with the good stuff). No thanks. Any other options? $75 negot. w/ everything seals bolts sender cover and plate, no taco sauce.. Sorry, I do not know if there is another super cheap way, maybe the dipstick temp. thngys i see time to time.. http://www.thesamba.com/vw/classifieds/detail.php?id=1087476 Nice find, but how do I know if this one isn't already tweaked and will leak? (IMG:style_emoticons/default/idea.gif) From past threads I've read, these things will leak if they are a hair off. Am I too skeptical or should I be leary about a used part from a stranger that holds the lifeblood of my engine? (IMG:style_emoticons/default/blink.gif) But seriously...NICE FIND! |
| detoxcowboy |
Jan 28 2011, 10:26 PM
Taco plates are not that plentiful or cheap. No to mention they have a tendency to leak and there is a reason they're called "taco" if not perfectly torqued. I would need the taco plate, cover and sender. That's around $100 right? Not to mention draining all my oil (which I just changed with the good stuff). No thanks. Any other options? $75 negot. w/ everything seals bolts sender cover and plate, no taco sauce.. Sorry, I do not know if there is another super cheap way, maybe the dipstick temp. thngys i see time to time.. http://www.thesamba.com/vw/classifieds/detail.php?id=1087476 Nice find, but how do I know if this one isn't already tweaked and will leak? (IMG:style_emoticons/default/idea.gif) From past threads I've read, these things will leak if they are a hair off. Am I too skeptical or should I be leary about a used part from a stranger that holds the lifeblood of my engine? (IMG:style_emoticons/default/blink.gif) But seriously...NICE FIND! Seriously they are easy to instal if your patient and do not over tight the 2 little bolts, they just have to crush the tiny winy copper seals that is it done.. people will straight strip the &$&^% threads like its holding back the prssure of niagara falls.. ask me how I know, then thank the po. of my 914.. fixed it though go to go.. |
Black22 Temp Guage Sender Jan 28 2011, 09:33 PM
detoxcowboy I would just use the taco sensor... you have to ha... Jan 28 2011, 09:52 PM
detoxcowboy seals are cheap if that is the issue.. Jan 28 2011, 09:53 PM
orange914 i origanly had a hard line heat/pressure sensative... Jan 28 2011, 10:13 PM
detoxcowboy Here is the $13 answer.. found what I said VD... Jan 28 2011, 10:23 PM
detoxcowboy
Here is the $13 answer.. found what I said V... Jan 28 2011, 10:28 PM
Black22 Thanks Detox, you're a wealth of info.
Have y... Jan 28 2011, 10:29 PM
detoxcowboy
Have ... Jan 28 2011, 10:39 PM
detoxcowboy Here is another one, maybe they will sell it to yo... Jan 28 2011, 10:48 PM
detoxcowboy 2 more w/ links
Oil Drain Plug Sender (may need s... Jan 28 2011, 10:57 PM
detoxcowboy basically from what i take is that if you using a ... Jan 28 2011, 11:02 PM
detoxcowboy Final note; anyone whom has vdo gauges, factory or... Jan 28 2011, 11:30 PM
detoxcowboy missed the obvious fit for the drain plug..
http:... Jan 29 2011, 12:38 AM
Black22 Thanks again Detox.
I did a little more research ... Jan 29 2011, 01:33 AM
McMark The drain plug sender will read lower than reality... Jan 29 2011, 12:57 PM
Vacca Rabite I'm just going to say that I bought two of tho... Jan 29 2011, 02:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:39 PM |
