| Black22 |
Jan 28 2011, 09:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Hey Fellas,
I'm looking for alternative senders to use with a Temp. Gauge that's part of the combo gas gauge. I know what the stock/correct sender type and placement is, but I don't want the hassle of the taco plate mounting and issues associated with that. Is there another sender that works with this gauge that is an easy and cheap alternative? I figure even if the gauge reads high or low, as long as it is functional and not pinned full on or off I can get an idea of where the "safe" range is. After all there aren't any temp. numbers on it. Anyone tried this Guage with a drain plug sender or anything else? (IMG:style_emoticons/default/confused24.gif) Just curious. Thanks, Mike |
| detoxcowboy |
Jan 28 2011, 10:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Here is another one, maybe they will sell it to you without the gauge..
plus you can ask them questions while deleting the gauge from the sale.. appear to be 150c/300deg. temp range again.. http://www.thesamba.com/vw/classifieds/detail.php?id=1081580 ![]() |
Black22 Temp Guage Sender Jan 28 2011, 09:33 PM
detoxcowboy I would just use the taco sensor... you have to ha... Jan 28 2011, 09:52 PM
detoxcowboy seals are cheap if that is the issue.. Jan 28 2011, 09:53 PM
Black22 Taco plates are not that plentiful or cheap. No to... Jan 28 2011, 10:01 PM
detoxcowboy
Taco plates are not that plentiful or cheap. No t... Jan 28 2011, 10:11 PM
Black22
Taco plates are not that plentiful or cheap. No ... Jan 28 2011, 10:17 PM
detoxcowboy
[quote name='detoxcowboy' post='1423865' date='Ja... Jan 28 2011, 10:26 PM
orange914 i origanly had a hard line heat/pressure sensative... Jan 28 2011, 10:13 PM
detoxcowboy Here is the $13 answer.. found what I said VD... Jan 28 2011, 10:23 PM
detoxcowboy
Here is the $13 answer.. found what I said V... Jan 28 2011, 10:28 PM
Black22 Thanks Detox, you're a wealth of info.
Have y... Jan 28 2011, 10:29 PM
detoxcowboy
Have ... Jan 28 2011, 10:39 PM
detoxcowboy 2 more w/ links
Oil Drain Plug Sender (may need s... Jan 28 2011, 10:57 PM
detoxcowboy basically from what i take is that if you using a ... Jan 28 2011, 11:02 PM
detoxcowboy Final note; anyone whom has vdo gauges, factory or... Jan 28 2011, 11:30 PM
detoxcowboy missed the obvious fit for the drain plug..
http:... Jan 29 2011, 12:38 AM
Black22 Thanks again Detox.
I did a little more research ... Jan 29 2011, 01:33 AM
McMark The drain plug sender will read lower than reality... Jan 29 2011, 12:57 PM
Vacca Rabite I'm just going to say that I bought two of tho... Jan 29 2011, 02:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:42 PM |
