> Temp Guage Sender, Options?
Black22
post Jan 28 2011, 09:33 PM
Hey Fellas,
I'm looking for alternative senders to use with a Temp. Gauge that's part of the combo gas gauge.
I know what the stock/correct sender type and placement is, but I don't want the hassle of the taco plate mounting and issues associated with that. Is there another sender that works with this gauge that is an easy and cheap alternative? I figure even if the gauge reads high or low, as long as it is functional and not pinned full on or off I can get an idea of where the "safe" range is. After all there aren't any temp. numbers on it.
Anyone tried this Guage with a drain plug sender or anything else? (IMG:style_emoticons/default/confused24.gif) Just curious.
Thanks,
Mike
detoxcowboy
post Jan 28 2011, 11:30 PM
Region Association: Africa
Final note; anyone whom has vdo gauges, factory or not oil or cht ect should read this link on what your really seeing at the needle on on the gauge..
make sense... but helps you read the dummy gauge like a pro dummy (IMG:style_emoticons/default/biggrin.gif)
http://www.ratwell.com/technical/VDOGauges.html
I think the clocks are pretty accurate though.. analog
Black22   Temp Guage Sender   Jan 28 2011, 09:33 PM
detoxcowboy   I would just use the taco sensor... you have to ha...   Jan 28 2011, 09:52 PM
detoxcowboy   seals are cheap if that is the issue..   Jan 28 2011, 09:53 PM
Black22   Taco plates are not that plentiful or cheap. No to...   Jan 28 2011, 10:01 PM
detoxcowboy   Taco plates are not that plentiful or cheap. No t...   Jan 28 2011, 10:11 PM
Black22   Taco plates are not that plentiful or cheap. No ...   Jan 28 2011, 10:17 PM
detoxcowboy   [quote name='detoxcowboy' post='1423865' date='Ja...   Jan 28 2011, 10:26 PM
orange914   i origanly had a hard line heat/pressure sensative...   Jan 28 2011, 10:13 PM
detoxcowboy   Here is the $13 answer.. found what I said VD...   Jan 28 2011, 10:23 PM
detoxcowboy   Here is the $13 answer.. found what I said V...   Jan 28 2011, 10:28 PM
Black22   Thanks Detox, you're a wealth of info. Have y...   Jan 28 2011, 10:29 PM
detoxcowboy   Thanks Detox, you're a wealth of info. Have ...   Jan 28 2011, 10:39 PM
detoxcowboy   Here is another one, maybe they will sell it to yo...   Jan 28 2011, 10:48 PM
detoxcowboy   2 more w/ links Oil Drain Plug Sender (may need s...   Jan 28 2011, 10:57 PM
detoxcowboy   basically from what i take is that if you using a ...   Jan 28 2011, 11:02 PM
detoxcowboy   Final note; anyone whom has vdo gauges, factory or...   Jan 28 2011, 11:30 PM
detoxcowboy   missed the obvious fit for the drain plug.. http:...   Jan 29 2011, 12:38 AM
Black22   Thanks again Detox. I did a little more research ...   Jan 29 2011, 01:33 AM
McMark   The drain plug sender will read lower than reality...   Jan 29 2011, 12:57 PM
Vacca Rabite   I'm just going to say that I bought two of tho...   Jan 29 2011, 02:51 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 PM
