TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
What is the best method to block the air injection ports on the late model heads? All I have is two holes. I know there is susposed to be tubes in the holes, but they aren't there.
Thanks in advance, Curt |
2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
Plug with a 55mm length bolt of the correct thread and some high temp locktite...
The only problem is the bolt head might interfere with the intake manifold flange when you try to bolt it on...It's a pretty tight fit but after the bolt is in, you could carefully grind it off a little bit for the desired clearance... don't get the debris in the intake port... 2-OH! |
Lo-Fi Version | Time is now: 11th August 2025 - 05:26 AM |
