Another coilover question thread, threaded collars for Koni / Bilstein, same size? |
PlaysWithCars |
Jan 23 2011, 05:17 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Sorry if this has been covered already, but all of the searching and reading I've done has only led to confusion.
I bought a set of new threaded collars as part of a package with new Koni sport shocks. The collars didn't fit as tight as I would have expected so I pulled out a spare set of Bilstein shocks to see it they fit them any better (I recalled reading that Koni and Bilstein required different sized collars and thought I may have gotten the wrong ones). Anyway, they fit the Bilsteins about the same. So, out came the calipers and the shock bodies are essentially the same diameter: Bilstein - 1.973" / Koni - 1.978". I also measured two other shock sets and got the same results. So, I'm concluding the shock bodies are essentially the same. (IMG:style_emoticons/default/confused24.gif) I found this post in the forum (http://www.914world.com/bbs2/index.php?sho...amp;hl=coilover) that talked about using an adapter from Coleman Racing and this one from JP where he used a plastic "shim" to get his fitting correctly (http://www.914world.com/bbs2/index.php?sho...amp;hl=coilover). Is this just nature of the beast that they don't fit tightly and need to have a adapter or shim installed? Is it the same story regardless of shock manufacturer? Any guidance would be appreciated. |
campbellcj |
Jan 29 2011, 02:35 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I had the same concern with the collars fitting a bit loosely, although I chose to not do anything about it (yet). Has not been a problem in practical usage thus far. Although I drive on relatively smooth tracks with no JUMPS like above!
Lo-Fi Version | Time is now: 1st June 2024 - 05:24 AM |
