> Temp Guage Sender, Options?
Black22
post Jan 28 2011, 09:33 PM
Hey Fellas,
I'm looking for alternative senders to use with a Temp. Gauge that's part of the combo gas gauge.
I know what the stock/correct sender type and placement is, but I don't want the hassle of the taco plate mounting and issues associated with that. Is there another sender that works with this gauge that is an easy and cheap alternative? I figure even if the gauge reads high or low, as long as it is functional and not pinned full on or off I can get an idea of where the "safe" range is. After all there aren't any temp. numbers on it.
Anyone tried this Guage with a drain plug sender or anything else? (IMG:style_emoticons/default/confused24.gif) Just curious.
Thanks,
Mike
VaccaRabite
post Jan 29 2011, 02:51 PM
En Garde!
I'm just going to say that I bought two of those drain plug senders, and neither of them actually fit the drain pug threads on my case. They did fit the taco plate threads. I am currently using one in my taco plate off a different engine.
For what its worth, my case was a bus case, so the drain plug may be different, but I doubt it.
Zach
Black22   Temp Guage Sender   Jan 28 2011, 09:33 PM
detoxcowboy   I would just use the taco sensor... you have to ha...   Jan 28 2011, 09:52 PM
detoxcowboy   seals are cheap if that is the issue..   Jan 28 2011, 09:53 PM
Black22   Taco plates are not that plentiful or cheap. No to...   Jan 28 2011, 10:01 PM
detoxcowboy   Taco plates are not that plentiful or cheap. No t...   Jan 28 2011, 10:11 PM
Black22   Taco plates are not that plentiful or cheap. No ...   Jan 28 2011, 10:17 PM
detoxcowboy   [quote name='detoxcowboy' post='1423865' date='Ja...   Jan 28 2011, 10:26 PM
orange914   i origanly had a hard line heat/pressure sensative...   Jan 28 2011, 10:13 PM
detoxcowboy   Here is the $13 answer.. found what I said VD...   Jan 28 2011, 10:23 PM
detoxcowboy   Here is the $13 answer.. found what I said V...   Jan 28 2011, 10:28 PM
Black22   Thanks Detox, you're a wealth of info. Have y...   Jan 28 2011, 10:29 PM
detoxcowboy   Thanks Detox, you're a wealth of info. Have ...   Jan 28 2011, 10:39 PM
detoxcowboy   Here is another one, maybe they will sell it to yo...   Jan 28 2011, 10:48 PM
detoxcowboy   2 more w/ links Oil Drain Plug Sender (may need s...   Jan 28 2011, 10:57 PM
detoxcowboy   basically from what i take is that if you using a ...   Jan 28 2011, 11:02 PM
detoxcowboy   Final note; anyone whom has vdo gauges, factory or...   Jan 28 2011, 11:30 PM
detoxcowboy   missed the obvious fit for the drain plug.. http:...   Jan 29 2011, 12:38 AM
Black22   Thanks again Detox. I did a little more research ...   Jan 29 2011, 01:33 AM
McMark   The drain plug sender will read lower than reality...   Jan 29 2011, 12:57 PM
Vacca Rabite   I'm just going to say that I bought two of tho...   Jan 29 2011, 02:51 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:37 PM
