> No idle - '74 2.0l FI
watsonrx13
post Jan 17 2011, 06:55 AM
Since I've rebuilt my '74 2.0l FI engine I've had problems with the car not idling. After it warms up it dies. I've set the timing to 27 and the dwell is at 46. I tried adjusting the ECU knob and the air idle screw but neither appear to have any effect on the idle. When I adjust the knob I can feel it click. I counted 21 total clicks. The engine runs great above idle. The injectors have been rebuilt, new AA vacuum hoses replaced, all gaskets are new.
Can the ECU be taken apart and cleaned?
Does anyone have a pic of the ECU opened up showing the knob area?
Any recommendations on how to fix the idle problem I'm having?
-- Rob
Jeffs9146
post Feb 1 2011, 07:02 PM
Ski Bum
(IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif)
I win!! (IMG:style_emoticons/default/beerchug.gif)
watsonrx13   No idle - '74 2.0l FI   Jan 17 2011, 06:55 AM
gasman   First check that the AAR is fully closed when warm...   Jan 17 2011, 10:11 AM
r_towle   I would agree that something else it wrong. The kn...   Jan 17 2011, 10:16 AM
Jeffs9146   Check your CHTS (Cylinder Head Temp Sensor) This...   Jan 17 2011, 10:20 AM
jsayre914   Vacume leak?? Check all the hoses are tight and ma...   Jan 17 2011, 11:33 AM
watsonrx13   So if I read Brad website correctly I need a 0 280...   Jan 17 2011, 11:57 AM
Krieger   So if I read Brad website correctly I need a 0 28...   Jan 17 2011, 12:27 PM
messix   oil fill cap not tight?   Jan 17 2011, 01:15 PM
r_towle   Here is how I go about this...and it works. Unplug...   Jan 17 2011, 02:24 PM
SLITS   Make sure the knob is in the middle of the range ....   Jan 17 2011, 08:26 PM
detoxcowboy   Since I've rebuilt my '74 2.0l FI engine ...   Jan 18 2011, 12:23 AM
detoxcowboy   I also have a 74 2.0, :agree: there is another pr...   Jan 18 2011, 11:07 AM
watsonrx13   I was finally able to work on the car this weekend...   Jan 31 2011, 05:23 PM
sfrenck   I was finally able to work on the car this weeken...   Jan 31 2011, 06:12 PM
Spoke   I took the car out for a quick drive and didn...   Feb 1 2011, 10:55 AM
detoxcowboy   I took the car out for a quick drive and didn...   Feb 1 2011, 11:33 AM
watsonrx13   more pics.. Here's how I tested the AAR.....   Jan 31 2011, 05:24 PM
Jeffs9146   I still vote for CHTS!!!!   Jan 31 2011, 05:51 PM
detoxcowboy   CHT Value and issue, Function: Senses engine tem...   Jan 31 2011, 06:19 PM
watsonrx13   Thanks guys. I also believe it appears to be a pro...   Jan 31 2011, 07:19 PM
Jeffs9146   It is not hard but be very carefull not to cross...   Jan 31 2011, 07:43 PM
underthetire   It is not hard but be very carefull not to cros...   Feb 1 2011, 10:04 AM
brenz   It is not hard but be very carefull not to cros...   Feb 1 2011, 11:34 AM
Spoke   One simple test you can do to make sure your CHT i...   Feb 1 2011, 05:58 AM
detoxcowboy   74 2.0 does not use the "missing" advanc...   Feb 1 2011, 08:11 AM
detoxcowboy   From the link I posted further up this post.. Th...   Feb 1 2011, 11:31 AM
watsonrx13   OK guys the engine started right up and is now idl...   Feb 1 2011, 04:46 PM
Jeffs9146   :first: :first: :first: :first: I win!...   Feb 1 2011, 07:02 PM
detoxcowboy   :hard: done, It's over! Congrats! CHT ...   Feb 1 2011, 07:57 PM
- Lo-Fi Version Time is now: 22nd October 2026 - 10:15 PM
