| crxnug |
Feb 2 2011, 12:46 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 20-December 07 From: ontario, canada Member No.: 8,489 |
im hoping someone can answer this for me, are the ecu,s on a 1973 2.0 the same unit as on a 1974 2.0 , can i swap one for the other are are there differences?
| orange914 |
Feb 2 2011, 06:19 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
becouse the 73 ecu was used for both the 2.0 and 1.7, it was "scabbed" together to run the newly added 2.0 with a different CHT(017) and an inline resister to trick it to fit the modified needs. i may be wrong but if you use a 74 ecu you will need to match the CHT and MPS. i dont think you'll need anything else... anyone?
check here http://members.rennlist.com/pbanders/DjetParts.htm not to hy jack but, why are the 73-74 green 2.0 injectors a different # than green 2.0 75-76? |
crxnug are the ECU,s on the 1973 and 74 2.0 the same? Feb 2 2011, 12:46 PM
dr914@autoatlanta.com There were quite a few different ones as the years... Feb 2 2011, 12:56 PM
detoxcowboy http://members.rennlist.com/pbanders/DJetParts.htm Feb 2 2011, 01:01 PM
Tom_T IIRC there were different ECUs & many other EF... Feb 2 2011, 02:16 PM
Bleyseng Huge difference between a 73 2.0l and a 74 2.0L Ge... Feb 2 2011, 04:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th June 2026 - 03:33 PM |
