| 913B |
Nov 8 2010, 05:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
So I ask the FLAPS parts person for fuel line hose and he gives me this. Then I check online with the SAE J30R7 rating stamped on the hose. It says operating PSI is 50 and burst psi is 250.
http://www.goodyearep.com/ProductsDetail.aspx?id=10526 Is it safe ? Perhaps some members with deeper knowledge can confirm?? If so whats with the warning of dont use on FI cars ? Maybe modern FI cars and not the ones like 39 years ago maybe. Thank you all !! Ted (IMG:style_emoticons/default/beerchug.gif) |
| realred914 |
Feb 4 2011, 06:26 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
the 30R9 is still lined with a flouropolymer, some is blue (maybe discontinued) but some is black lined, so it is hard to see (but still detectable) the SAE specification calls out for a liner. all 30R9 will have some color of a liner, black, blue what ever
the 1/4 inch wont fit right, you may get it on, but it may also eventually tear. the elbows from the factory as far as i know are NOT lined, and will degrade with todays mandated fuels (thanks to the envioro-nut jobs at CARB, be sure to vote out of office any legislator that supports CARB, get informed!) You can simply use a striaght piece of 30R9, cut the right length and it will work, just cut the length so the radius does not totally pinch down, been doing that for a while, (many years) that will work for you, much better than using the curved hose of inferior quality from a degregation stand point. some 30R7 hose is now being marketed with a warning "Not for fuel injection" this used to be the stuff to use, but not anymore. flouropolymers..... better living thru better chemistry! |
porsche913b_sp 5/16 Fuel Hose for 1.7 D-Jet Nov 8 2010, 05:10 PM
underthetire Buy the injection hose with the colored liner. Our... Nov 8 2010, 05:24 PM
jk76.914 Correct lines are 7mm ID x 3mm wall, with means th... Nov 8 2010, 05:33 PM
Racer Chris
Correct lines are 7mm ID x 3mm wall, with means t... Nov 8 2010, 06:06 PM
jk76.914
Have you ever actually measured the od of the tub... Nov 8 2010, 06:27 PM
porsche913b_sp Hmm, thanks for the good advice. Nov 8 2010, 07:17 PM
realred914 5/16 inch is a great fit, wont fail with clamps. ... Nov 8 2010, 07:38 PM
Rotary'14
5/16 inch is a great fit, wont fail with clamps. ... Nov 8 2010, 07:53 PM
realred914
5/16 inch is a great fit, wont fail with clamps.... Nov 8 2010, 08:07 PM
porsche913b_sp So I am back to fuel line replacement project. So ... Dec 11 2010, 08:31 PM
bandjoey I don't know the ratings. A year ago I bought... Dec 11 2010, 11:17 PM
patssle When you guys say the R7 degrades because of the f... Dec 11 2010, 11:29 PM
underthetire Well, the one piece I replaced with the R7 stuff s... Dec 12 2010, 12:17 AM
dangrouche R9 rated hose; cut by the foot, cost about $7... Dec 12 2010, 01:35 AM
AvalonFal I posted this pic a while back, but here's an ... Dec 12 2010, 11:01 AM
realred914
I posted this pic a while back, but here's an... Dec 12 2010, 11:21 AM
AvalonFal
I posted this pic a while back, but here's a... Dec 13 2010, 08:53 AM
76-914 :popcorn: Dec 12 2010, 12:39 PM
jk76.914 Does anybody make the elbow hoses to the fuel inje... Dec 12 2010, 07:53 PM
jsconst
Does anybody make the elbow hoses to the fuel inj... Feb 4 2011, 12:27 AM
underthetire
Does anybody make the elbow hoses to the fuel in... Feb 4 2011, 10:07 AM
type11969 Hoses to the fuel injectors are the same hose as e... Dec 12 2010, 08:57 PM
Cupomeat
Hoses to the fuel injectors are the same hose as ... Dec 12 2010, 09:14 PM
porsche913b_sp
Does anybody make the elbow hoses to the fuel inj... Dec 12 2010, 10:36 PM
tod914 Just use a short piece of the R9 line. Next time ... Dec 12 2010, 11:17 PM
jk76.914 Unleaded??? How old IS that hose? Dec 13 2010, 05:36 PM
type11969 Just a heads up, but the blue liner has been disco... Dec 13 2010, 09:02 PM
914_teener
Just a heads up, but the blue liner has been disc... Feb 3 2011, 10:55 PM
porsche913b_sp On a tip from my friend pep boys carrys the SAE 30... Feb 3 2011, 11:30 PM
type11969 Gooodyear stopped using the liner, but the replace... Feb 4 2011, 06:19 AM
underthetire http://www.rockauto.com/catalog/raframecat...64-27... Feb 4 2011, 10:12 AM
76-914 Has anyone w/ FI used the 1/4" SAE 30R9 inste... Feb 4 2011, 10:34 AM
underthetire
Has anyone w/ FI used the 1/4" SAE 30R9 inst... Feb 4 2011, 11:42 AM
76-914 Being the hard headed individual that I am, I wrot... Feb 4 2011, 02:04 PM
elmonte Found this on-line. Great price, but you have to b... Feb 4 2011, 02:16 PM
SLITS
Found this on-line. Great price, but you have to ... Feb 5 2011, 09:11 AM
elmonte
[quote name='elmonte' post='1427082' date='Feb 4 ... Feb 5 2011, 01:58 PM
ELLIOTT wonder how many feet in the roll? Feb 4 2011, 02:45 PM
elmonte
25 ft Feb 4 2011, 02:57 PM
underthetire Great price. Might have to pick up a roll next tim... Feb 4 2011, 03:41 PM
Rex-n-effect Go to your local VW or Audi dealer and buy part # ... Feb 4 2011, 04:46 PM
nathansnathan
Go to your local VW or Audi dealer and buy part #... Feb 4 2011, 05:18 PM
jim_hoyland How many feet does a typical FI car require, inclu... Feb 4 2011, 05:43 PM
914_teener
the 30R9 is still lined with a flouropolymer, som... Feb 4 2011, 06:41 PM
76-914 When you say a roll you don't mention which si... Feb 4 2011, 06:50 PM
fasthonda I found the best deal for goodyear 30R9 @ Greasec... Feb 4 2011, 08:29 PM
jimkelly see this ??
http://www.914world.com/bbs2/index.ph... Feb 5 2011, 10:55 AM
76-914 Just a quick update. I have been in touch w/ the f... Feb 15 2011, 10:35 AM
jim_hoyland Has anyone verified that non-30R9 fuel hose actual... Feb 15 2011, 11:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:49 PM |
