> 5/16 Fuel Hose for 1.7 D-Jet, Source for SAE 30R9 (FI fuel hose) ??
913B
post Nov 8 2010, 05:10 PM
So I ask the FLAPS parts person for fuel line hose and he gives me this. Then I check online with the SAE J30R7 rating stamped on the hose. It says operating PSI is 50 and burst psi is 250.
http://www.goodyearep.com/ProductsDetail.aspx?id=10526
Is it safe ? Perhaps some members with deeper knowledge can confirm??
If so whats with the warning of dont use on FI cars ? Maybe modern FI cars and not the ones like 39 years ago maybe.
Thank you all !!
Ted
realred914
post Feb 4 2011, 06:26 PM
Group: Retired Members
the 30R9 is still lined with a flouropolymer, some is blue (maybe discontinued) but some is black lined, so it is hard to see (but still detectable) the SAE specification calls out for a liner. all 30R9 will have some color of a liner, black, blue what ever
the 1/4 inch wont fit right, you may get it on, but it may also eventually tear.
the elbows from the factory as far as i know are NOT lined, and will degrade with todays mandated fuels (thanks to the envioro-nut jobs at CARB, be sure to vote out of office any legislator that supports CARB, get informed!)
You can simply use a striaght piece of 30R9, cut the right length and it will work, just cut the length so the radius does not totally pinch down, been doing that for a while, (many years) that will work for you, much better than using the curved hose of inferior quality from a degregation stand point.
some 30R7 hose is now being marketed with a warning "Not for fuel injection" this used to be the stuff to use, but not anymore.
flouropolymers..... better living thru better chemistry!
914_teener
post Feb 4 2011, 06:41 PM
QUOTE(realred914 @ Feb 4 2011, 04:26 PM) *
Yes...California fuels require the "reformulation" it does cause the non 30R9 to degrade. I am redoing all the FI lines in my car and couldn't find the Goodyear manufactured stuff here on the West Coast.
Thanks for everyone for their help....great forum.
Looks like the best source is Gates now which has a SAE tested number on it. I wasn't quite sure if the "Cleveland" sourced hose had the testing designation.
porsche913b_sp   5/16 Fuel Hose for 1.7 D-Jet   Nov 8 2010, 05:10 PM
underthetire   Buy the injection hose with the colored liner. Our...   Nov 8 2010, 05:24 PM
jk76.914   Correct lines are 7mm ID x 3mm wall, with means th...   Nov 8 2010, 05:33 PM
Racer Chris   Correct lines are 7mm ID x 3mm wall, with means t...   Nov 8 2010, 06:06 PM
jk76.914   Have you ever actually measured the od of the tub...   Nov 8 2010, 06:27 PM
porsche913b_sp   Hmm, thanks for the good advice.   Nov 8 2010, 07:17 PM
realred914   5/16 inch is a great fit, wont fail with clamps. ...   Nov 8 2010, 07:38 PM
Rotary'14   5/16 inch is a great fit, wont fail with clamps. ...   Nov 8 2010, 07:53 PM
realred914   5/16 inch is a great fit, wont fail with clamps....   Nov 8 2010, 08:07 PM
porsche913b_sp   So I am back to fuel line replacement project. So ...   Dec 11 2010, 08:31 PM
bandjoey   I don't know the ratings. A year ago I bought...   Dec 11 2010, 11:17 PM
patssle   When you guys say the R7 degrades because of the f...   Dec 11 2010, 11:29 PM
underthetire   Well, the one piece I replaced with the R7 stuff s...   Dec 12 2010, 12:17 AM
dangrouche   R9 rated hose; cut by the foot, cost about $7...   Dec 12 2010, 01:35 AM
AvalonFal   I posted this pic a while back, but here's an ...   Dec 12 2010, 11:01 AM
realred914   I posted this pic a while back, but here's an...   Dec 12 2010, 11:21 AM
AvalonFal   I posted this pic a while back, but here's a...   Dec 13 2010, 08:53 AM
76-914   :popcorn:   Dec 12 2010, 12:39 PM
jk76.914   Does anybody make the elbow hoses to the fuel inje...   Dec 12 2010, 07:53 PM
jsconst   Does anybody make the elbow hoses to the fuel inj...   Feb 4 2011, 12:27 AM
underthetire   Does anybody make the elbow hoses to the fuel in...   Feb 4 2011, 10:07 AM
type11969   Hoses to the fuel injectors are the same hose as e...   Dec 12 2010, 08:57 PM
Cupomeat   Hoses to the fuel injectors are the same hose as ...   Dec 12 2010, 09:14 PM
porsche913b_sp   Does anybody make the elbow hoses to the fuel inj...   Dec 12 2010, 10:36 PM
tod914   Just use a short piece of the R9 line. Next time ...   Dec 12 2010, 11:17 PM
jk76.914   Unleaded??? How old IS that hose?   Dec 13 2010, 05:36 PM
type11969   Just a heads up, but the blue liner has been disco...   Dec 13 2010, 09:02 PM
914_teener   Just a heads up, but the blue liner has been disc...   Feb 3 2011, 10:55 PM
porsche913b_sp   On a tip from my friend pep boys carrys the SAE 30...   Feb 3 2011, 11:30 PM
type11969   Gooodyear stopped using the liner, but the replace...   Feb 4 2011, 06:19 AM
underthetire   http://www.rockauto.com/catalog/raframecat...64-27...   Feb 4 2011, 10:12 AM
76-914   Has anyone w/ FI used the 1/4" SAE 30R9 inste...   Feb 4 2011, 10:34 AM
underthetire   Has anyone w/ FI used the 1/4" SAE 30R9 inst...   Feb 4 2011, 11:42 AM
76-914   Being the hard headed individual that I am, I wrot...   Feb 4 2011, 02:04 PM
elmonte   Found this on-line. Great price, but you have to b...   Feb 4 2011, 02:16 PM
SLITS   Found this on-line. Great price, but you have to ...   Feb 5 2011, 09:11 AM
elmonte   [quote name='elmonte' post='1427082' date='Feb 4 ...   Feb 5 2011, 01:58 PM
ELLIOTT   wonder how many feet in the roll?   Feb 4 2011, 02:45 PM
elmonte   wonder how many feet in the roll? 25 ft   Feb 4 2011, 02:57 PM
underthetire   Great price. Might have to pick up a roll next tim...   Feb 4 2011, 03:41 PM
Rex-n-effect   Go to your local VW or Audi dealer and buy part # ...   Feb 4 2011, 04:46 PM
nathansnathan   Go to your local VW or Audi dealer and buy part #...   Feb 4 2011, 05:18 PM
jim_hoyland   How many feet does a typical FI car require, inclu...   Feb 4 2011, 05:43 PM
realred914   the 30R9 is still lined with a flouropolymer, some...   Feb 4 2011, 06:26 PM
914_teener   the 30R9 is still lined with a flouropolymer, som...   Feb 4 2011, 06:41 PM
76-914   When you say a roll you don't mention which si...   Feb 4 2011, 06:50 PM
fasthonda   I found the best deal for goodyear 30R9 @ Greasec...   Feb 4 2011, 08:29 PM
jimkelly   see this ?? http://www.914world.com/bbs2/index.ph...   Feb 5 2011, 10:55 AM
76-914   Just a quick update. I have been in touch w/ the f...   Feb 15 2011, 10:35 AM
jim_hoyland   Has anyone verified that non-30R9 fuel hose actual...   Feb 15 2011, 11:04 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:49 PM
