> What went wrong, fire
914itis
post Feb 4 2011, 09:06 PM
I decided to install my hangman fuse panel. after installing i started the car, turn on
the head lights - works
flashers- works
turn signals- works
decided to turn on the wipers works, then the engine cuts off followed by a spark on the fuse area. within seconds the wires was on fire. I safely put out the fire.
I then removed the fuse box, to notice that the big red wire was burning, that wire was attached to a brown piece that looks like a breaker. it cracks ast it burns out.
My question is what is that brown peice is used for that has the brown wires attached on one side and the big red one on the other end.. I know that the brown wires are ground.
now that peice is gone what do I do..?
A good portion of the red wire is melted. and I will be inspecting the rest of the wires for burnt.
help!
Tom
post Feb 5 2011, 10:59 AM
I didn't see anyone mention this, so I thought I would. You said you just installed the fuse panel upgrade? Maybe one of the wires got caught between ground and the fuse panel during reinstallation? Check the red wires for marks to see if one has a dent in it where the insulation has been crushed. This would have taken your + to ground and that is unfused at that point. Hope everything turns out OK. I put the J-West one in my 76 and the fog light flasher at the same time. It seemed to be too tight when I pushed the fuse panel back up, so I made a couple of spacers to lower the fuse panel a 1/4 inch so I didn't have too much pressure on the wires. Just needed slightly longer screws after that to hold the panel up. It has been fine for 3-4 years.
Tom
ppetion   What went wrong   Feb 4 2011, 09:06 PM
SirAndy   :ttiwwp: I'm guessing it's one of the re...   Feb 4 2011, 09:09 PM
ppetion   :ttiwwp: I'm guessing it's one of the r...   Feb 4 2011, 09:11 PM
SirAndy   its not a relay, it is screwed on top of the speak...   Feb 4 2011, 09:21 PM
ppetion   its not a relay, it is screwed on top of the spea...   Feb 4 2011, 09:30 PM
tomeric914   It sounds like they are describing the group of br...   Feb 4 2011, 09:32 PM
ppetion   It sounds like they are describing the group of b...   Feb 4 2011, 09:34 PM
76-914   it sounds like the ground wires from the door swit...   Feb 4 2011, 09:38 PM
montoya 73 2.0   I dont think a big red wire is supposed to be grou...   Feb 4 2011, 10:02 PM
ppetion   I dont think a big red wire is supposed to be gro...   Feb 4 2011, 10:23 PM
ppetion   the wire shown on picture # 2 was attached to the ...   Feb 4 2011, 11:06 PM
larss   the wire shown on picture # 2 was attached to the...   Feb 4 2011, 11:18 PM
ppetion   the wire shown on picture # 2 was attached to th...   Feb 4 2011, 11:26 PM
SirAndy   the wire shown on picture # 2 was attached to the ...   Feb 5 2011, 02:20 PM
larss   The bakelite thing seems to be available at Autoat...   Feb 4 2011, 11:42 PM
ppetion   thanks ... is there some special function to it, o...   Feb 4 2011, 11:46 PM
larss   No special function other than a good electrical i...   Feb 4 2011, 11:53 PM
ppetion   No special function other than a good electrical ...   Feb 4 2011, 11:55 PM
Tom   I didn't see anyone mention this, so I thought...   Feb 5 2011, 10:59 AM
tradisrad   for what it is worth my '70 has the same ...   Feb 5 2011, 11:21 AM
Vacca Rabite   Sorry to see the mess that you've got. Maybe ...   Feb 5 2011, 11:36 AM
tradisrad   zach, you are probably right about not using the l...   Feb 5 2011, 11:59 AM
underthetire   I see some serious melting on a couple brown wires...   Feb 5 2011, 12:38 PM
ppetion   I see some serious melting on a couple brown wire...   Feb 5 2011, 03:15 PM
PeeGreen 914   Sorry to hear this all happened after upgrading yo...   Feb 5 2011, 01:49 PM
Joe Owensby   I agree with Zach's recommendation to check ev...   Feb 6 2011, 11:03 AM
realred914   the addition of a fusable link at the battery woul...   Feb 6 2011, 11:23 AM
ppetion   Update! the batery wire is fried all the way t...   Feb 6 2011, 07:15 PM
ppetion   Update! the batery wire is fried all the way ...   Feb 7 2011, 10:34 PM
porsche913b_sp   ppetion, glad to see your car is fixed. Members,...   Feb 7 2011, 10:50 PM
ppetion   ppetion, glad to see your car is fixed. Members...   Feb 7 2011, 11:15 PM
montoya 73 2.0   IIRC bake-lite is that plastic like material that ...   Feb 7 2011, 11:00 PM
Dave_Darling   Bakelite was one of the earlier plastics. It was ...   Feb 8 2011, 12:00 AM
hcdmueller   "bakelite" is a hard material that can b...   Feb 8 2011, 12:01 AM
spankmeister7   Ah, bakelite! Bakelite is really the first p...   Feb 8 2011, 12:07 AM
larss   I was the one introducing the word "bakelite...   Feb 8 2011, 12:21 AM
ppetion   I was the one introducing the word "bakelite...   Feb 8 2011, 12:27 AM
Vacca Rabite   Dude! You work fast! Doing all that wir...   Feb 8 2011, 09:06 AM
ppetion   Dude! You work fast! Doing all that wi...   Feb 8 2011, 09:18 AM
- Lo-Fi Version Time is now: 12th August 2026 - 05:13 AM
