> What went wrong, fire
914itis
post Feb 4 2011, 09:06 PM
I decided to install my hangman fuse panel. after installing i started the car, turn on
the head lights - works
flashers- works
turn signals- works
decided to turn on the wipers works, then the engine cuts off followed by a spark on the fuse area. within seconds the wires was on fire. I safely put out the fire.
I then removed the fuse box, to notice that the big red wire was burning, that wire was attached to a brown piece that looks like a breaker. it cracks ast it burns out.
My question is what is that brown peice is used for that has the brown wires attached on one side and the big red one on the other end.. I know that the brown wires are ground.
now that peice is gone what do I do..?
A good portion of the red wire is melted. and I will be inspecting the rest of the wires for burnt.
help!
914itis
post Feb 6 2011, 07:15 PM
Update! the batery wire is fried all the way to the battery. I spent 6 Hours removing the wire and inspecting every single wire that was on that batch, There was some other sligtly damadge wire that would probably cause an issue if grounded. I did the repair from the battery to the fuse box. I used a distribution box mounted under the dash nest to the fuse box. The battery wire coming in and the other 3 wires that was attached to the original wire coming out. I also added the 60 amp fuse box by the battery.. There are two other positive battery wire going to the relay box by the driver's side of the engine, I used a one 30 amps fuses for eacch.
I also confirmed that it was a long screw that that I used to crew the new fuse panel that touched the wire on the isolator... DON'T LET THIS HAPPEN TO YOU!
Thanks all for all your concerns and help as always..
Paul
ppetion   What went wrong   Feb 4 2011, 09:06 PM
SirAndy   :ttiwwp: I'm guessing it's one of the re...   Feb 4 2011, 09:09 PM
ppetion   :ttiwwp: I'm guessing it's one of the r...   Feb 4 2011, 09:11 PM
SirAndy   its not a relay, it is screwed on top of the speak...   Feb 4 2011, 09:21 PM
ppetion   its not a relay, it is screwed on top of the spea...   Feb 4 2011, 09:30 PM
tomeric914   It sounds like they are describing the group of br...   Feb 4 2011, 09:32 PM
ppetion   It sounds like they are describing the group of b...   Feb 4 2011, 09:34 PM
76-914   it sounds like the ground wires from the door swit...   Feb 4 2011, 09:38 PM
montoya 73 2.0   I dont think a big red wire is supposed to be grou...   Feb 4 2011, 10:02 PM
ppetion   I dont think a big red wire is supposed to be gro...   Feb 4 2011, 10:23 PM
ppetion   the wire shown on picture # 2 was attached to the ...   Feb 4 2011, 11:06 PM
larss   the wire shown on picture # 2 was attached to the...   Feb 4 2011, 11:18 PM
ppetion   the wire shown on picture # 2 was attached to th...   Feb 4 2011, 11:26 PM
SirAndy   the wire shown on picture # 2 was attached to the ...   Feb 5 2011, 02:20 PM
larss   The bakelite thing seems to be available at Autoat...   Feb 4 2011, 11:42 PM
ppetion   thanks ... is there some special function to it, o...   Feb 4 2011, 11:46 PM
larss   No special function other than a good electrical i...   Feb 4 2011, 11:53 PM
ppetion   No special function other than a good electrical ...   Feb 4 2011, 11:55 PM
Tom   I didn't see anyone mention this, so I thought...   Feb 5 2011, 10:59 AM
tradisrad   for what it is worth my '70 has the same ...   Feb 5 2011, 11:21 AM
Vacca Rabite   Sorry to see the mess that you've got. Maybe ...   Feb 5 2011, 11:36 AM
tradisrad   zach, you are probably right about not using the l...   Feb 5 2011, 11:59 AM
underthetire   I see some serious melting on a couple brown wires...   Feb 5 2011, 12:38 PM
ppetion   I see some serious melting on a couple brown wire...   Feb 5 2011, 03:15 PM
PeeGreen 914   Sorry to hear this all happened after upgrading yo...   Feb 5 2011, 01:49 PM
Joe Owensby   I agree with Zach's recommendation to check ev...   Feb 6 2011, 11:03 AM
realred914   the addition of a fusable link at the battery woul...   Feb 6 2011, 11:23 AM
ppetion   Update! the batery wire is fried all the way t...   Feb 6 2011, 07:15 PM
ppetion   Update! the batery wire is fried all the way ...   Feb 7 2011, 10:34 PM
porsche913b_sp   ppetion, glad to see your car is fixed. Members,...   Feb 7 2011, 10:50 PM
ppetion   ppetion, glad to see your car is fixed. Members...   Feb 7 2011, 11:15 PM
montoya 73 2.0   IIRC bake-lite is that plastic like material that ...   Feb 7 2011, 11:00 PM
Dave_Darling   Bakelite was one of the earlier plastics. It was ...   Feb 8 2011, 12:00 AM
hcdmueller   "bakelite" is a hard material that can b...   Feb 8 2011, 12:01 AM
spankmeister7   Ah, bakelite! Bakelite is really the first p...   Feb 8 2011, 12:07 AM
larss   I was the one introducing the word "bakelite...   Feb 8 2011, 12:21 AM
ppetion   I was the one introducing the word "bakelite...   Feb 8 2011, 12:27 AM
Vacca Rabite   Dude! You work fast! Doing all that wir...   Feb 8 2011, 09:06 AM
ppetion   Dude! You work fast! Doing all that wi...   Feb 8 2011, 09:18 AM
- Lo-Fi Version Time is now: 12th August 2026 - 05:14 AM
