| John |
Jan 13 2011, 09:54 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I will convert to a 911 steering column. I have parts for both (with the exception of an early horn contact), and am debating in my head of which one to use.
If I use the early parts, it would "look" more period correct, but the switches just aren't as nice and seem to be harder to come by. If I use the later model 911 parts, I can easily get replacements, but it just won't look the same. I'm a little biased toward using the early parts, but I'm still "on the fence" when it comes to deciding. Thanks for your input. |
| dflesburg |
Feb 7 2011, 07:51 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
very pretty.
I thought I told you that early cars had different mount patterns when we talked about this last summer in Oxford. |
John POLL : 911 Steering Column Jan 13 2011, 09:54 PM
I will convert to a 911 steering column. I have ... Jan 13 2011, 10:05 PM
914Sixer I like the early. Jan 14 2011, 06:52 AM
dflesburg I used the early one. in my car.
Jan 14 2011, 08:22 AM
John Hmm.
10 to 1 so far. I didn't realize it wou... Jan 15 2011, 09:29 PM
John
late model
early
early Jan 16 2011, 07:23 PM
John Dash mod....
Jan 21 2011, 06:01 PM
SirAndy Dash mod....
:thumbsup:
I used the attachment pie... Jan 24 2011, 12:00 PM
John
Dash mod....
:thumbsup:
I used the attachment pi... Jan 25 2011, 08:21 PM
John I re-did the mount plate lowering it down a bit.
... Jan 23 2011, 06:24 PM
SirAndy Here's mine mounted, like i said, yours looks ... Jan 25 2011, 09:13 PM
John Must be a few different versions of early switches... Jan 25 2011, 09:38 PM
Must be a few different versions of early switche... Jan 25 2011, 09:56 PM
John So Andy, since you have done this, I have a questi... Jan 25 2011, 10:06 PM
SirAndy My question is: Did you eliminate the headlight di... Jan 28 2011, 01:16 PM
John
My question is: Did you eliminate the headlight d... Jan 28 2011, 08:23 PM
John Minor setback.
I made my bracket fit my 71 unit b... Feb 5 2011, 08:57 PM
SirAndy Who knew the bolt patterns changed between years?
... Feb 6 2011, 01:20 AM
John Setbacks.
Oh well, it's just cutting welding ... Feb 6 2011, 04:33 PM
SirAndy I'm moving the fog light switch to the other s... Feb 6 2011, 05:01 PM
John
Zinc plated and treated with yellow chromate. Feb 6 2011, 09:47 PM
John
very pretty.
I thought I told you that early car... Feb 7 2011, 12:19 PM
John A little more progress and it lives! I starte... Mar 12 2011, 11:23 PM
jaxdream That cutout may be for the old style dash mounted ... Mar 13 2011, 09:08 AM
SirAndy That cutout may be for the old style dash mounted ... Mar 13 2011, 05:18 PM
type47fan Headlight cleaner/washer option "spray contro... Mar 13 2011, 12:04 PM
John I believe that Wayne nailed it. Headlight washers... Mar 13 2011, 08:49 PM
John Getting closer......
New vinyl
Installed dash ... Mar 20 2011, 09:20 PM
dflesburg Great Job, now all you need is the early lower das... Mar 21 2011, 06:44 AM
John
Great Job, now all you need is the early lower da... Mar 21 2011, 09:28 PM
dflesburg cool by me. Mar 22 2011, 09:46 AM
John After getting everything back together, I did more... Mar 23 2011, 07:14 PM
John Wrapped it up today.
Mar 26 2011, 08:13 PM
John Here is a tool I made and some screws I yellow chr... Mar 26 2011, 08:17 PM
jaxdream What is the tool for ????
Jack / Jaxdream Mar 27 2011, 08:42 AM
John
Jack / Jaxdream
I g... Mar 27 2011, 08:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:22 PM |
