Overbeek driving a 935, At Laguna |
Randal |
Feb 7 2011, 07:26 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
You just got to love the lines, especially in 2, 9 and 11.
http://www.youtube.com/watch?v=VnYzvOBoPx4&NR=1 https://www.youtube.com/watch?v=VnYzvOBoPx4&NR |
DanT |
Feb 7 2011, 11:22 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
His lines were fairly typical for a car with big race slicks and tons of HP and low weight.
The double apex at turn 2 is one of two approaches that is accepted as the quick way around the turn, the other being staying wider at entry and then sweeping into the apex (decreasing radius corner). Double apex is something many 911 drivers use while many 914 and Boxster drivers use the decreasing radius with one late apex. He was not really running race lines anywhere... He was looking for quick lap times, not keeping someone behind him...also this stuff is gentleman racing with these historic mega dollar machines. (IMG:style_emoticons/default/biggrin.gif) At turn 9 again his line was very typical of a full blow race car on slicks...he was leaving lots on the table there....but then again, if you go off driver's right at that area you end up going sideways into a drainage ditch...not optimal for a guest drive in a historic race car.... His lap times were in the 1:32 range, which is really moving at Laguna in a full bodied race car. Quickest I have been on track at Laguna is in the 1:42 range which was in a 911 based racecar on slicks in 40* ambient temps...and that was a real eye opener for car control the first few laps (IMG:style_emoticons/default/smile.gif) until the tires finally got a bit of heat in them... at full tilt I am sure he would be sweeping in a bit wider at turn 9 and exiting a bit wider. I used to have to shift my 914-6 RS motor car mid corner at 9 and that was before the GP motorcycle changes that deepened and enlarged the gravel/sand trap and moved the bridge (abuttment was the issue) further up towards turn 8. Also the distance from turn 9 to turn 10 has increased when the track was updated a few years back, as well as the distance from 10 to 11. I have been driving Laguna for 20+ years now, and there have been some very significant changes over the years with repaving, new berms, and actual changes in the track layout. : And they took out the Oak Tree. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 04:30 PM |
