Difference between a 2.0L out of a bus or 914 |
carnitasboy |
Feb 10 2011, 09:42 AM
Newbie Group: Members Posts: 2 Joined: 8-March 10 From: San Diego Member No.: 11,444 Region Association: Southwest Region |
Is there a difference in a 2.0L out of a bus as opposed to a 2.0L out of a 914? I was under the assumption that a bus engine had different heads. I don't know where I heard that. Maybe I just made that up.
Root_Werks |
Feb 10 2011, 09:56 AM
Village Idiot Group: Members Posts: 8,338 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
There are a number of differences between the two. Just a few I know of (Depends on the year of the bus vs 914):
Bus: 4 bolt intake heads with smaller valves No windage tray Different cam Used L-Jet for I think all versions 78-79 came in a carb'd version that had a mechanical fuel pump Bus engines are lower reving torque monsters compared to 914 2.0s There are tons more differences I'm sure. That's what's off the top of my little head. |
Cap'n Krusty |
Feb 10 2011, 10:01 AM
There are a number of differences between the two. Just a few I know of (Depends on the year of the bus vs 914): Bus: 4 bolt intake heads with smaller valves No windage tray Different cam Used L-Jet for I think all versions 78-79 came in a carb'd version that had a mechanical fuel pump Bus engines are lower reving torque monsters compared to 914 2.0s There are tons more differences I'm sure. That's what's off the top of my little head. Many of the few differences you 'know" are wrong. The carbed versions were 1972-1974, all the others had L-jet. The cam was the same until 1977, AFIK, when they changed to hydraulic lifters. They'll rev the same as 2.0 914 engines, but the power is somewhat reduced by the head design, the hydraulic cam, and the L-jet EFI. The Cap'n |
Root_Werks |
Feb 10 2011, 01:00 PM
There are a number of differences between the two. Just a few I know of (Depends on the year of the bus vs 914): Bus: 4 bolt intake heads with smaller valves No windage tray Different cam Used L-Jet for I think all versions 78-79 came in a carb'd version that had a mechanical fuel pump Bus engines are lower reving torque monsters compared to 914 2.0s There are tons more differences I'm sure. That's what's off the top of my little head. Many of the few differences you 'know" are wrong. The carbed versions were 1972-1974, all the others had L-jet. The cam was the same until 1977, AFIK, when they changed to hydraulic lifters. They'll rev the same as 2.0 914 engines, but the power is somewhat reduced by the head design, the hydraulic cam, and the L-jet EFI. The Cap'n Frig an egg, goes to show how much I DON'T know. (IMG:style_emoticons/default/rolleyes.gif) I have to remember to keep my mouth shut, some poor idiot might actually listen one of these days. |
Lo-Fi Version | Time is now: 16th June 2024 - 08:22 AM |
