| Randal |
Feb 14 2011, 06:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I am going to be putting my engine in by myself, so trying to get everything lined up so it will be a smooth process.
My throttle bodies and fuel rails are wider than the stock sheet metal, so will be removing one of them so I won't have to use crazy angles (again) to get the engine back up in there. My engine is about as high as one with Webers. I've built two large wide ramps and extra blocks so that I can have the rear wheel about 14" off the ground. Don't have my car here so can't test it out, but figured all you jack stand / car ramp guys will know if that is high enough for my engine to fit under the bumper. If not, some more 2 x 6's are going to get cut up for blocks. |
| ChrisFoley |
Feb 15 2011, 09:51 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
One of our lift plates gets the engine down to about 4" from the floor, on a jack that will raise it 14" or more (IMG:style_emoticons/default/smile.gif)
With the TBs out of the way you have a chance with the car at the level you mentioned Randal. You may have to get creative lowering the car a little bit to meet the engine before any of the bolts will go in. |
| Randal |
Feb 15 2011, 02:14 PM
One of our lift plates gets the engine down to about 4" from the floor, on a jack that will raise it 14" or more (IMG:style_emoticons/default/smile.gif) With the TBs out of the way you have a chance with the car at the level you mentioned Randal. You may have to get creative lowering the car a little bit to meet the engine before any of the bolts will go in. Thanks Chris. As you suggested the TB's will be out of the way. I'd cut the sheet metal, but Paul (built my engine) would be unhappy given all the effort he took to maintain engine cooling. After carefully looking at one of the HF transmission jacks I decided to buy one for this job. It has the ability to alter angle fairly dramatically basically North, South East or West. It is made pretty well and I think it will do what is needed. We'll see how it works when I have the motor, along with the transmission, on it. BTW I made a block to protect the special oil sump and that fits precisely into the top of the jack plate. I'll strap the engine to that plate with tie down straps. So I should be able to get the engine to the right height to allow the bolts to go in. Just waiting until this rain goes away and then the motor is going in. We need that T-Shirt weather that was here last week! |
| ChrisFoley |
Feb 15 2011, 07:52 PM
Randal Engine Installation Feb 14 2011, 06:41 PM
J P Stein For my weber carbed 2.7L I needed 32 inches from t... Feb 14 2011, 06:56 PM
Borderline I don't like having the car that high in the a... Feb 14 2011, 11:20 PM
draganc Great looking engine and very interesting setup... Feb 15 2011, 10:16 PM
Randal
Great looking engine and very interesting setup... Feb 16 2011, 05:02 AM
draganc
Great looking engine and very interesting setup... Feb 16 2011, 07:34 AM
McMark Dragan, looks like a Hall Effect sensor (mine is V... Feb 19 2011, 02:13 PM
draganc Randal sorry for the highjack and thank you Mark f... Feb 19 2011, 10:23 PM
J P Stein I spent 10-12 winters under my 914. I hate jacksta... Feb 20 2011, 09:06 AM
Randal
I spent 10-12 winters under my 914. I hate jackst... Feb 23 2011, 07:01 PM
grantsfo Man you guys are fancy. I remember my 914 first e... Feb 23 2011, 03:34 PM
J P Stein Without going out to my cold garage, I recall they... Feb 23 2011, 08:57 PM
Randal
Without going out to my cold garage, I recall the... Feb 24 2011, 10:08 AM
J P Stein
I'll bet they are stout. When it gets warm en... Feb 24 2011, 10:44 AM
Randal
I'll bet they are stout. When it gets warm e... Feb 25 2011, 10:12 PM
Randal The next phase of the installation begins tomorrow... Feb 25 2011, 10:15 PM
J P Stein My outside thermometer says 16F this morning......... Feb 26 2011, 09:18 AM
Randal
My outside thermometer says 16F this morning........ Feb 26 2011, 05:08 PM
Randal
My outside thermometer says 16F this morning....... Mar 2 2011, 11:14 AM
DrifterJay I always found it extremely easy to just remove th... Feb 26 2011, 06:34 PM
Randal
I always found it extremely easy to just remove t... Feb 27 2011, 09:53 PM
McMark What linkage are you using with your TWMs? Feb 28 2011, 03:20 PM
Randal
I th... Feb 28 2011, 10:20 PM
McMark I only ask because I've had poor experiences w... Mar 1 2011, 01:00 AM
Randal
I only ask because I've had poor experiences ... Mar 2 2011, 11:05 AM
orchid914 Randal,
I put the front and back of the 914 on Ja... Mar 1 2011, 01:35 PM
Randal
Randal,
I put the front and back of the 914 on J... Mar 2 2011, 11:07 AM
Randal OK, I'll show one as the installation of the e... Mar 2 2011, 04:18 PM
Randal I have a Tilton starter in "222" which i... Mar 20 2011, 11:03 AM
McMark :rotfl: Maybe we need to make you a fiberglass pa... Mar 21 2011, 05:54 PM
Randal
:rotfl: Maybe we need to make you a fiberglass p... Mar 23 2011, 12:17 PM
Randal
:rotfl: Maybe we need to make you a fiberglass ... Mar 26 2011, 10:44 AM
Randal I'm ready to fire her up now.
Looking forward... Mar 30 2011, 10:37 PM
McMark Video... B:) Mar 30 2011, 10:43 PM
Randal I'm going to borrow Bill's pre-oiler next ... Apr 1 2011, 10:36 PM
Randal
I'm going to borrow Bill's pre-oiler next... Apr 15 2011, 10:46 AM
jjackson How is it going? Are you ready to run it?JJackson ... Apr 16 2011, 08:11 PM
Randal
How is it going? Are you ready to run it?JJackson... Apr 16 2011, 10:35 PM
jjackson Congrats on getting her up and running.Hp really l... Apr 19 2011, 07:24 PM
Randal $6.25 is a great deal. :cheer:
Out here in... Apr 20 2011, 08:55 AM
Randal Taking the car to the dyno on Thursday to confirm ... May 11 2011, 09:37 AM
grantsfo
Taking the car to the dyno on Thursday to confirm... May 12 2011, 03:29 PM
Randal Ended up with 174 hp at the rear wheels and the sa... May 12 2011, 10:03 PM
grantsfo
Ended up with 174 hp at the rear wheels and the s... May 12 2011, 10:26 PM
J P Stein
[Not bad for 40 year old engine technology! W... May 13 2011, 07:11 AM
PeeGreen 914 Can't wait to see this car run :beer2: This i... May 13 2011, 09:37 AM
Randal
Can't wait to see this car run :beer2: This ... May 13 2011, 09:54 PM
HAM Inc Randall I'm so glad to hear that it is perform... May 14 2011, 09:21 AM
jjackson
Randall I'm so glad to hear that it is perfor... May 14 2011, 12:35 PM
Randal
Randall I'm so glad to hear that it is perfo... May 14 2011, 10:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:27 PM |
