Difficult Corners, At the track |
Randal |
Feb 15 2011, 02:21 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
The most challenging corners I've experienced are turn 1 at Thunderhill (counterclockwise) and turn 10 at Sears. I'd also say turn 9 at Thunderhill when running clockwise. By challenging I mean corners that are tough to get right and take at maximum speed. |
DanT |
Feb 15 2011, 03:39 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
If we are talking about TT/DE lines here goes.
Turn one TH CCW. after the pit wall get as far right as possible for set up for entry. stay right during braking (don't cheat left). Smooth turn in (fairly high speed turn entry) and very late apex at the end of the inside berm. Then exit all the way right using the entire exit berm. Turn 9 at TH CW. Going uphill can not see the apex. Either get off the gas as you get near the top of the hill or completely crest the hill and do some pretty aggressive braking (yes there is enough room to wait to brake here). Get the car all the way to the right at the apex(end of berm). Exit all the way to the left. |
SirAndy |
Feb 16 2011, 05:44 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Turn 9 at TH CW. Going uphill can not see the apex. Do you stay all the way left going over the top? (IMG:style_emoticons/default/idea.gif) I've only run it that direction once and had nobody with me to show me the lines ... (IMG:style_emoticons/default/driving.gif) |
Randal |
Feb 17 2011, 09:33 AM
Turn 9 at TH CW. Going uphill can not see the apex. Do you stay all the way left going over the top? (IMG:style_emoticons/default/idea.gif) I've only run it that direction once and had nobody with me to show me the lines ... (IMG:style_emoticons/default/driving.gif) That was my question as well after reading Dan's first tutorial. Thanks for the clarification Dan. Actually there is a lot going on at that corner. (IMG:style_emoticons/default/driving-girl.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 11:35 PM |
