Front yellow Konis, and the bump stop |
tradisrad |
Feb 19 2011, 10:57 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I have put some yellow adjustable konis in my car and I cut one of the three bump stops off (the soft one on the top,stock parts, not the ones that came with the konis. yet). I've got just shy of two inches of suspension travel, I would to get as much travel as possible w/o bottoming the shocks or raising the car. I have not bottomed onto the stops yet, but I've not driven it too much since the swap.
Am I safe to cut one more of the bump stops off and only have one stop section ? Should I use the stock stops or koni provided stops? thanks -Rob |
sean_v8_914 |
Feb 19 2011, 12:55 PM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
hmmm... what component needs break in inside a shock? rings to seat? cam to lifter face?
I slapped yellows on ziggy and went straight to willow. same shocks are on 10jreen now you could also shorten your strut housings and run rabbit inserts |
Lo-Fi Version | Time is now: 17th June 2024 - 12:34 PM |
