> Engine Installation, Question
Randal
post Feb 14 2011, 06:41 PM
I am going to be putting my engine in by myself, so trying to get everything lined up so it will be a smooth process.
My throttle bodies and fuel rails are wider than the stock sheet metal, so will be removing one of them so I won't have to use crazy angles (again) to get the engine back up in there. My engine is about as high as one with Webers.
I've built two large wide ramps and extra blocks so that I can have the rear wheel about 14" off the ground.
Don't have my car here so can't test it out, but figured all you jack stand / car ramp guys will know if that is high enough for my engine to fit under the bumper.
If not, some more 2 x 6's are going to get cut up for blocks.
J P Stein
post Feb 23 2011, 08:57 PM
Irrelevant old fart
Without going out to my cold garage, I recall they are made out of a basic 16 inch max cut.......rip a 4 X 8 plywood sheet into 3 ea.16 inch wide strips....less the kerf.
This makes 18, 16 inch (approx) squares. Inside each box is a X cross brace top to bottom & 2X2s in the corners.
Screw & glue the whole works together, some HF swivel casters and ya have 3 boxes.....less the X brace which requires more wood. IIRC, it took 2 sheets of 3/4 plywood. They stand about 22-23 inches tall with the casters......IIRC. It's snowing
intermittently & I'm staying in the warm house.
The 16 inch squares go at the top & bottom and the rest get trimmed to fit as required. When your done you'll have a BS degree in plywood management. (IMG:style_emoticons/default/biggrin.gif)
They are stout.
Randal
post Feb 24 2011, 10:08 AM
QUOTE(J P Stein @ Feb 23 2011, 06:57 PM) *
They are stout.
I'll bet they are stout. When it gets warm enough to make the garage trip please show a picture of how you did the X brace. Thanks.
J P Stein
post Feb 24 2011, 10:44 AM
Irrelevant old fart
QUOTE(Randal @ Feb 24 2011, 08:08 AM) *
The braces are permanently enclosed in the boxes so discription will have to do.
Once you have the 4 sides on the bottom of your box, measure the inside width.....prolly around 14-1/2 inches. Rip 2 of your 16 inch squares to that width.
Find the center of that width & layout a 3/4 ( actually 11/16 cause 3/4 ply ain't) inch slot X 8 inches deep & centered on that CL. Cut it out on 2 pieces and shove them together.....slot to slot (tight fits are gud)....now you have an X brace.
A couple 2 X 2s where they join for screwing/glueing purposes makes em' solid and locked within the box.
One needs a good table saw with an accurate fence.....a cabniet shop is the perfect place to find one. I built mine.......the build discription would run to pages if I could remember how I did it. (IMG:style_emoticons/default/confused24.gif) WAG bout 6-700 lbs.....but it's on casters. (IMG:style_emoticons/default/biggrin.gif)
We ended up with 3-4 inches of snow last night so I'm taking vacation today.....to shovel my steep driveway clear.....bummer.
Randal   Engine Installation   Feb 14 2011, 06:41 PM
J P Stein   For my weber carbed 2.7L I needed 32 inches from t...   Feb 14 2011, 06:56 PM
Borderline   I don't like having the car that high in the a...   Feb 14 2011, 11:20 PM
Racer Chris   One of our lift plates gets the engine down to abo...   Feb 15 2011, 09:51 AM
Randal   One of our lift plates gets the engine down to ab...   Feb 15 2011, 02:14 PM
Racer Chris   BTW I made a block to protect the special oil su...   Feb 15 2011, 07:52 PM
draganc   Great looking engine and very interesting setup...   Feb 15 2011, 10:16 PM
Randal   Great looking engine and very interesting setup...   Feb 16 2011, 05:02 AM
draganc   Great looking engine and very interesting setup...   Feb 16 2011, 07:34 AM
McMark   Dragan, looks like a Hall Effect sensor (mine is V...   Feb 19 2011, 02:13 PM
draganc   Randal sorry for the highjack and thank you Mark f...   Feb 19 2011, 10:23 PM
J P Stein   I spent 10-12 winters under my 914. I hate jacksta...   Feb 20 2011, 09:06 AM
Randal   I spent 10-12 winters under my 914. I hate jackst...   Feb 23 2011, 07:01 PM
grantsfo   Man you guys are fancy. I remember my 914 first e...   Feb 23 2011, 03:34 PM
J P Stein   Without going out to my cold garage, I recall they...   Feb 23 2011, 08:57 PM
Randal   Without going out to my cold garage, I recall the...   Feb 24 2011, 10:08 AM
J P Stein   I'll bet they are stout. When it gets warm en...   Feb 24 2011, 10:44 AM
Randal   I'll bet they are stout. When it gets warm e...   Feb 25 2011, 10:12 PM
Randal   The next phase of the installation begins tomorrow...   Feb 25 2011, 10:15 PM
J P Stein   My outside thermometer says 16F this morning.........   Feb 26 2011, 09:18 AM
Randal   My outside thermometer says 16F this morning........   Feb 26 2011, 05:08 PM
Randal   My outside thermometer says 16F this morning.......   Mar 2 2011, 11:14 AM
DrifterJay   I always found it extremely easy to just remove th...   Feb 26 2011, 06:34 PM
Randal   I always found it extremely easy to just remove t...   Feb 27 2011, 09:53 PM
McMark   What linkage are you using with your TWMs?   Feb 28 2011, 03:20 PM
Randal   What linkage are you using with your TWMs? I th...   Feb 28 2011, 10:20 PM
McMark   I only ask because I've had poor experiences w...   Mar 1 2011, 01:00 AM
Randal   I only ask because I've had poor experiences ...   Mar 2 2011, 11:05 AM
orchid914   Randal, I put the front and back of the 914 on Ja...   Mar 1 2011, 01:35 PM
Randal   Randal, I put the front and back of the 914 on J...   Mar 2 2011, 11:07 AM
Randal   OK, I'll show one as the installation of the e...   Mar 2 2011, 04:18 PM
Randal   I have a Tilton starter in "222" which i...   Mar 20 2011, 11:03 AM
McMark   :rotfl: Maybe we need to make you a fiberglass pa...   Mar 21 2011, 05:54 PM
Randal   :rotfl: Maybe we need to make you a fiberglass p...   Mar 23 2011, 12:17 PM
Randal   :rotfl: Maybe we need to make you a fiberglass ...   Mar 26 2011, 10:44 AM
Randal   I'm ready to fire her up now. Looking forward...   Mar 30 2011, 10:37 PM
McMark   Video... B:)   Mar 30 2011, 10:43 PM
Randal   I'm going to borrow Bill's pre-oiler next ...   Apr 1 2011, 10:36 PM
Randal   I'm going to borrow Bill's pre-oiler next...   Apr 15 2011, 10:46 AM
jjackson   How is it going? Are you ready to run it?JJackson ...   Apr 16 2011, 08:11 PM
Randal   How is it going? Are you ready to run it?JJackson...   Apr 16 2011, 10:35 PM
jjackson   Congrats on getting her up and running.Hp really l...   Apr 19 2011, 07:24 PM
Randal   $6.25 is a great deal. :cheer: Out here in...   Apr 20 2011, 08:55 AM
Randal   Taking the car to the dyno on Thursday to confirm ...   May 11 2011, 09:37 AM
grantsfo   Taking the car to the dyno on Thursday to confirm...   May 12 2011, 03:29 PM
Randal   Ended up with 174 hp at the rear wheels and the sa...   May 12 2011, 10:03 PM
grantsfo   Ended up with 174 hp at the rear wheels and the s...   May 12 2011, 10:26 PM
J P Stein   [Not bad for 40 year old engine technology! W...   May 13 2011, 07:11 AM
PeeGreen 914   Can't wait to see this car run :beer2: This i...   May 13 2011, 09:37 AM
Randal   Can't wait to see this car run :beer2: This ...   May 13 2011, 09:54 PM
HAM Inc   Randall I'm so glad to hear that it is perform...   May 14 2011, 09:21 AM
jjackson   Randall I'm so glad to hear that it is perfor...   May 14 2011, 12:35 PM
Randal   Randall I'm so glad to hear that it is perfo...   May 14 2011, 10:21 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:54 PM
