| HarveyH |
Apr 2 2004, 11:09 AM
Member ![]() ![]() Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
I'll be replacing the shocks and struts soon, (IMG:style_emoticons/default/smash.gif) and was wondering what other items should be replaced as a matter of course. Street car, slightly lowered, steering rack spacer, factory rear sway bar, 100 Lb rear springs, and KYB's (IMG:style_emoticons/default/headbang.gif) . I have a new 19mm front bar to go in, so I've identified the 19mm bushings, F & R drop link bushings. What else? (IMG:style_emoticons/default/confused24.gif) Will the stock snubbers on the front strut shaft (hopefully they are still there...) fit Bils?
Thanks, Harvey |
| maf914 |
Apr 2 2004, 11:56 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Depending on the age of your ball joints and tie rod ends, you may want to replace them at the same time. I did and was pleased with how solid the front end and steering felt. I used standard rod ends but most people would probably recommend turbo rod ends.
Mike |
HarveyH Recommended Replacement Items Apr 2 2004, 11:09 AM
madd_dogg_914 Well . . . as long as you are "in there" so to sp... Apr 2 2004, 11:30 AM
SirAndy trash the 19mm sway bar and get a 22mm or bigger.
... Apr 2 2004, 11:59 AM
lagunero Yeah like Maf914 said. I did the turbo ties since ... Apr 2 2004, 12:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 09:45 AM |
