Boxster muffler install, finished.....well almost |
toon1 |
Feb 26 2011, 10:26 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
This project(like all the others) has been on the "to do "list for awhile.
The mufller fits in the stock location pretty well even with the heat shield in place. If the heat shield was removed, it can go a little higher towards the trunk. I decided to go all stainless , which aint cheap, but will pay off in the long run. After all the hard work, I fired it up last night and I have an exhaust leak at the heads. It was 11pm so I shut the garage door and went to bed. I'm going to chase it down today. Here are soem pics. The first two show the hagers that need to be cut off. there are two on top that are threaded studs and to hangers on the back. Attached image(s) |
toon1 |
Feb 26 2011, 11:03 AM
I'm just wondering why you chose to put this muffler on Cool project... As I recall from my Boxster that muffler is kind of heavy but pretty neat application of the new on the old. I like the way it looks with the center outlet it's also a lot more quiet. Yes the muffler is heavy but not much more than the bursch collector and muffler assembly. The SS he's are quite a bit lighter than the stock steel HE's . The assemblies are probably withing 5lbs of eachother. |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:15 AM |
