ILM914 |
Member ![]() ![]() Group: Members Posts: 101 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None ![]() |
Hello fellow 914ers: My car is misbehaving. When I first start it, I can drive out fine aside from being a bit sluggish due to being cold (normal). After it warms up it acts awfull, bucking very hard and hesitating, seemingly running on 2 cyl at times. I have adjusted the valves, timed the car, put some new ingition parts (car has elec ignition, no points). Symptoms don't improve when I disconnect the plug for the throttle body switch. The fuel pump is fairly new and I feel perhaps if it were fuel pressure or dirty injectors it would run poorly consistantly. I have not changed the spark plug wires and coil because I have never had these parts fail on any cars I have ever owned. I changed the dual points inside the distributor with tested good working used ones. I suspect perhaps fuel clog maybe in the tank or filter or perhaps the cyl head temp sensor? Please give any advise you think may help. Thank you. Someone else must have had this exact problem.
indianmort |
Newbie ![]() Group: Members Posts: 14 Joined: 2-August 10 From: sugarloaf ny Member No.: 12,004 Region Association: None ![]() |
could also be the coil. when cold runs fine as it warms up coil expands. if there is a break in the windings, the ignition will break down. when is cools off it will run fine again.
Lo-Fi Version | Time is now: 5th July 2025 - 04:56 AM |
