| Dr Evil |
Mar 9 2011, 04:47 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I was looking into ways to do odd things to make more power. What else is new. I came across a standard, root type supercharger hooked up to a corvair engine that was pretty kick ass. I like superchargers in that they are cleaner to install that turbos and do not have the lag. Then, I found the Vortech centrifugal superchargers and felt that these just might be an interesting way to bolt on power.
http://www.vortechsuperchargers.com/catego...n=SUPERCHARGERS Cheap? No friggen way, but cool! Used ones can be gotten for much less if you know what model to use. I need to read up on what is required of an engine to be supercharged vs turbo charged if there is a difference in configuration. An interesting aside for my specific interests regarding the reverse running corvair engine; the 4cyl Honda ones would be easily adaptable, possibly. The only problem I see is that there are no 3.1L honda 4cyl engines. So, what do y'all know about supercharging? How about thoughts on doing it to a TIV or any other power plant that we could throw into our cars? |
| sean_v8_914 |
Mar 9 2011, 09:23 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
same way they did the AC. although it might need a beefier belt
914 had a pulley behind the impeller. belt exit went behind the fan housing to the right opposite teh alternator or maybe could be like they did the smog pump. it was mounted atop the fdan housing. there was an extender shaft in front of teh fan. the fan housing had a 3 legged bracket suspended in front of teh fan mounted to the 3 holes that the Bus used for teh fan screeen Jake has said that boosting teh type 4 creates head sealing challenges. perhaps modest boost #s would be OK |
Dr Evil Supercharger: Possibility for our engines? Mar 9 2011, 04:47 AM
Zimms Roots style blower
I am still a big turbo fan, th... Mar 9 2011, 06:16 AM
type47 Volumex supercharger
Mar 9 2011, 07:55 AM
rick 918-S Paxton has been around since the begining of hot r... Mar 9 2011, 08:06 AM
thelogo You need to add an AC clutch to the drive belt so ... Mar 9 2011, 12:01 PM
Vacca Rabite
could that actually be done , ala mad mel ... Mar 9 2011, 01:28 PM
SLITS Get a Supercharger off a Merceces Kompressor ... h... Mar 9 2011, 08:14 AM
Dr Evil
Get a Supercharger off a Merceces Kompressor ... ... Mar 9 2011, 08:42 AM
sixnotfour There is a boxster supercharger set up used for 3k... Mar 9 2011, 08:21 AM
sixnotfour Or there is this electric setup;
http://www.superc... Mar 9 2011, 08:29 AM
Dr Evil
http://www.super... Mar 9 2011, 08:37 AM
bozo914 Dick Landy Industries did a Rootes type for the Ty... Mar 9 2011, 08:31 AM
Hontec Mercedes SLK compressors are roots style and very ... Mar 9 2011, 08:58 AM
Dr Evil
Mercedes SLK compressors are roots style and very... Mar 9 2011, 09:04 AM
Dr Evil Ah, a fatal flaw in the centrifugal setup:
... Mar 9 2011, 09:01 AM
'73-914kid Now I want a supercharger on my 914.. thanks guys.... Mar 9 2011, 09:10 AM
type47
@Type47, is your motor able to breath with that c... Mar 9 2011, 04:55 PM
Dr Evil Question; can a SC bee hooked up to a CIS without ... Mar 9 2011, 09:21 AM
rohar
Question; can a SC bee hooked up to a CIS without... Mar 9 2011, 10:55 AM
banger You might want to look at a Corrado G60 supercharg... Mar 9 2011, 10:50 AM
rohar
You might want to look at a Corrado G60 superchar... Mar 9 2011, 12:01 PM
bandjoey Might as well look into alcohol injection too. :) Mar 9 2011, 11:15 AM
gandalf_025 I've never dealt with a supercharger, always t... Mar 9 2011, 11:25 AM
underthetire Hell, if your goin electric, you could just throw ... Mar 9 2011, 05:27 PM
Dave_Darling There isn't a lot of room at the top/front of ... Mar 10 2011, 12:39 AM
Rand "You can't supercharge a 914."
I wo... Mar 10 2011, 12:53 AM
Dr Evil I will likely SC the bus first.....or I might do t... Mar 10 2011, 01:12 AM
Dr Evil I had some time this evening to read up on CIS and... Mar 10 2011, 05:04 AM
rohar
I had some time this evening to read up on CIS an... Mar 10 2011, 09:15 AM
Dr Evil Here is a good diagram. Mar 10 2011, 07:16 AM
Vacca Rabite you probably already figured this out given the ch... Mar 10 2011, 08:13 AM
Dr Evil Thank you captain obvious :rolleyes: Mar 10 2011, 08:26 AM
sean_v8_914 anyone care to speculate as to why turbos are more... Mar 10 2011, 08:37 AM
Vacca Rabite
anyone care to speculate as to why turbos are mor... Mar 10 2011, 09:18 AM
J P Stein
anyone care to speculate as to why turbos are mor... Mar 10 2011, 09:30 AM
Vacca Rabite
anyone care to speculate as to why turbos are mo... Mar 10 2011, 09:44 AM
Dr Evil Here is another one: Mar 10 2011, 08:37 AM
sean_v8_914 is that a 911 turbo? Mar 10 2011, 08:43 AM
Dr Evil No Mar 10 2011, 09:06 AM
Dr Evil Since my overall intention is to put this into the... Mar 10 2011, 09:42 AM
rohar For a low boost bus, I'd go with a small SC. ... Mar 10 2011, 09:47 AM
Dr Evil Yup, the plan is the 230 SLK SC to be used :) Chea... Mar 10 2011, 10:00 AM
rohar
Yup, the plan is the 230 SLK SC to be used :) Che... Mar 10 2011, 10:43 AM
J P Stein You may note that I said "proper installation... Mar 10 2011, 10:00 AM
iamchappy
You may note that I said "proper installatio... Mar 10 2011, 10:57 AM
J P Stein An SC is no walk in the park either. Mar 10 2011, 10:40 AM
Dr Evil Uh, ya....that is more complicated than I want to ... Mar 10 2011, 08:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:07 PM |
