| Dr Evil |
Mar 9 2011, 04:47 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I was looking into ways to do odd things to make more power. What else is new. I came across a standard, root type supercharger hooked up to a corvair engine that was pretty kick ass. I like superchargers in that they are cleaner to install that turbos and do not have the lag. Then, I found the Vortech centrifugal superchargers and felt that these just might be an interesting way to bolt on power.
http://www.vortechsuperchargers.com/catego...n=SUPERCHARGERS Cheap? No friggen way, but cool! Used ones can be gotten for much less if you know what model to use. I need to read up on what is required of an engine to be supercharged vs turbo charged if there is a difference in configuration. An interesting aside for my specific interests regarding the reverse running corvair engine; the 4cyl Honda ones would be easily adaptable, possibly. The only problem I see is that there are no 3.1L honda 4cyl engines. So, what do y'all know about supercharging? How about thoughts on doing it to a TIV or any other power plant that we could throw into our cars? |
| gandalf_025 |
Mar 9 2011, 11:25 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,516 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
I've never dealt with a supercharger, always turbo's..
BUT, it looks like a supercharger would be simpler to plumb and would keep the exhaust away from the incoming air. And could be placed closer to the intake ports which would = less lag all by itself. The only question I would have is how much HP does it take to run it ? The big draw of a turbo is that it doesn't take HP to run relatively speaking. Unless you count the restriction in the exhaust flow. As far as the electric fan "Superchargers" I'd want a lot of proof they really do work.. Judson made superchargers for VW's and Corvairs in the 60's.. I have seen some show up on E-bay at times. |
Dr Evil Supercharger: Possibility for our engines? Mar 9 2011, 04:47 AM
Zimms Roots style blower
I am still a big turbo fan, th... Mar 9 2011, 06:16 AM
type47 Volumex supercharger
Mar 9 2011, 07:55 AM
rick 918-S Paxton has been around since the begining of hot r... Mar 9 2011, 08:06 AM
thelogo You need to add an AC clutch to the drive belt so ... Mar 9 2011, 12:01 PM
Vacca Rabite
could that actually be done , ala mad mel ... Mar 9 2011, 01:28 PM
SLITS Get a Supercharger off a Merceces Kompressor ... h... Mar 9 2011, 08:14 AM
Dr Evil
Get a Supercharger off a Merceces Kompressor ... ... Mar 9 2011, 08:42 AM
sixnotfour There is a boxster supercharger set up used for 3k... Mar 9 2011, 08:21 AM
sixnotfour Or there is this electric setup;
http://www.superc... Mar 9 2011, 08:29 AM
Dr Evil
http://www.super... Mar 9 2011, 08:37 AM
bozo914 Dick Landy Industries did a Rootes type for the Ty... Mar 9 2011, 08:31 AM
Hontec Mercedes SLK compressors are roots style and very ... Mar 9 2011, 08:58 AM
Dr Evil
Mercedes SLK compressors are roots style and very... Mar 9 2011, 09:04 AM
Dr Evil Ah, a fatal flaw in the centrifugal setup:
... Mar 9 2011, 09:01 AM
'73-914kid Now I want a supercharger on my 914.. thanks guys.... Mar 9 2011, 09:10 AM
type47
@Type47, is your motor able to breath with that c... Mar 9 2011, 04:55 PM
Dr Evil Question; can a SC bee hooked up to a CIS without ... Mar 9 2011, 09:21 AM
rohar
Question; can a SC bee hooked up to a CIS without... Mar 9 2011, 10:55 AM
sean_v8_914 same way they did the AC. although it might need a... Mar 9 2011, 09:23 AM
banger You might want to look at a Corrado G60 supercharg... Mar 9 2011, 10:50 AM
rohar
You might want to look at a Corrado G60 superchar... Mar 9 2011, 12:01 PM
bandjoey Might as well look into alcohol injection too. :) Mar 9 2011, 11:15 AM
underthetire Hell, if your goin electric, you could just throw ... Mar 9 2011, 05:27 PM
Dave_Darling There isn't a lot of room at the top/front of ... Mar 10 2011, 12:39 AM
Rand "You can't supercharge a 914."
I wo... Mar 10 2011, 12:53 AM
Dr Evil I will likely SC the bus first.....or I might do t... Mar 10 2011, 01:12 AM
Dr Evil I had some time this evening to read up on CIS and... Mar 10 2011, 05:04 AM
rohar
I had some time this evening to read up on CIS an... Mar 10 2011, 09:15 AM
Dr Evil Here is a good diagram. Mar 10 2011, 07:16 AM
Vacca Rabite you probably already figured this out given the ch... Mar 10 2011, 08:13 AM
Dr Evil Thank you captain obvious :rolleyes: Mar 10 2011, 08:26 AM
sean_v8_914 anyone care to speculate as to why turbos are more... Mar 10 2011, 08:37 AM
Vacca Rabite
anyone care to speculate as to why turbos are mor... Mar 10 2011, 09:18 AM
J P Stein
anyone care to speculate as to why turbos are mor... Mar 10 2011, 09:30 AM
Vacca Rabite
anyone care to speculate as to why turbos are mo... Mar 10 2011, 09:44 AM
Dr Evil Here is another one: Mar 10 2011, 08:37 AM
sean_v8_914 is that a 911 turbo? Mar 10 2011, 08:43 AM
Dr Evil No Mar 10 2011, 09:06 AM
Dr Evil Since my overall intention is to put this into the... Mar 10 2011, 09:42 AM
rohar For a low boost bus, I'd go with a small SC. ... Mar 10 2011, 09:47 AM
Dr Evil Yup, the plan is the 230 SLK SC to be used :) Chea... Mar 10 2011, 10:00 AM
rohar
Yup, the plan is the 230 SLK SC to be used :) Che... Mar 10 2011, 10:43 AM
J P Stein You may note that I said "proper installation... Mar 10 2011, 10:00 AM
iamchappy
You may note that I said "proper installatio... Mar 10 2011, 10:57 AM
J P Stein An SC is no walk in the park either. Mar 10 2011, 10:40 AM
Dr Evil Uh, ya....that is more complicated than I want to ... Mar 10 2011, 08:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:13 PM |
