> Supercharger: Possibility for our engines?
Dr Evil
post Mar 9 2011, 04:47 AM
Send me your transmission!
I was looking into ways to do odd things to make more power. What else is new. I came across a standard, root type supercharger hooked up to a corvair engine that was pretty kick ass. I like superchargers in that they are cleaner to install that turbos and do not have the lag. Then, I found the Vortech centrifugal superchargers and felt that these just might be an interesting way to bolt on power.
http://www.vortechsuperchargers.com/catego...n=SUPERCHARGERS
Cheap? No friggen way, but cool! Used ones can be gotten for much less if you know what model to use.
I need to read up on what is required of an engine to be supercharged vs turbo charged if there is a difference in configuration.
An interesting aside for my specific interests regarding the reverse running corvair engine; the 4cyl Honda ones would be easily adaptable, possibly. The only problem I see is that there are no 3.1L honda 4cyl engines.
So, what do y'all know about supercharging? How about thoughts on doing it to a TIV or any other power plant that we could throw into our cars?
Dr Evil
post Mar 10 2011, 07:16 AM
Here is a good diagram.
Dr Evil   Supercharger: Possibility for our engines?   Mar 9 2011, 04:47 AM
Zimms   Roots style blower I am still a big turbo fan, th...   Mar 9 2011, 06:16 AM
type47   Volumex supercharger   Mar 9 2011, 07:55 AM
rick 918-S   Paxton has been around since the begining of hot r...   Mar 9 2011, 08:06 AM
thelogo   You need to add an AC clutch to the drive belt so ...   Mar 9 2011, 12:01 PM
Vacca Rabite   could that actually be done , ala mad mel ...   Mar 9 2011, 01:28 PM
SLITS   Get a Supercharger off a Merceces Kompressor ... h...   Mar 9 2011, 08:14 AM
Dr Evil   Get a Supercharger off a Merceces Kompressor ... ...   Mar 9 2011, 08:42 AM
sixnotfour   There is a boxster supercharger set up used for 3k...   Mar 9 2011, 08:21 AM
sixnotfour   Or there is this electric setup; http://www.superc...   Mar 9 2011, 08:29 AM
Dr Evil   Or there is this electric setup; http://www.super...   Mar 9 2011, 08:37 AM
bozo914   Dick Landy Industries did a Rootes type for the Ty...   Mar 9 2011, 08:31 AM
Hontec   Mercedes SLK compressors are roots style and very ...   Mar 9 2011, 08:58 AM
Dr Evil   Mercedes SLK compressors are roots style and very...   Mar 9 2011, 09:04 AM
Dr Evil   Ah, a fatal flaw in the centrifugal setup: ...   Mar 9 2011, 09:01 AM
'73-914kid   Now I want a supercharger on my 914.. thanks guys....   Mar 9 2011, 09:10 AM
type47   @Type47, is your motor able to breath with that c...   Mar 9 2011, 04:55 PM
Dr Evil   Question; can a SC bee hooked up to a CIS without ...   Mar 9 2011, 09:21 AM
rohar   Question; can a SC bee hooked up to a CIS without...   Mar 9 2011, 10:55 AM
sean_v8_914   same way they did the AC. although it might need a...   Mar 9 2011, 09:23 AM
banger   You might want to look at a Corrado G60 supercharg...   Mar 9 2011, 10:50 AM
rohar   You might want to look at a Corrado G60 superchar...   Mar 9 2011, 12:01 PM
bandjoey   Might as well look into alcohol injection too. :)   Mar 9 2011, 11:15 AM
gandalf_025   I've never dealt with a supercharger, always t...   Mar 9 2011, 11:25 AM
underthetire   Hell, if your goin electric, you could just throw ...   Mar 9 2011, 05:27 PM
Dave_Darling   There isn't a lot of room at the top/front of ...   Mar 10 2011, 12:39 AM
Rand   "You can't supercharge a 914." I wo...   Mar 10 2011, 12:53 AM
Dr Evil   I will likely SC the bus first.....or I might do t...   Mar 10 2011, 01:12 AM
Dr Evil   I had some time this evening to read up on CIS and...   Mar 10 2011, 05:04 AM
rohar   I had some time this evening to read up on CIS an...   Mar 10 2011, 09:15 AM
Dr Evil   Here is a good diagram.   Mar 10 2011, 07:16 AM
Vacca Rabite   you probably already figured this out given the ch...   Mar 10 2011, 08:13 AM
Dr Evil   Thank you captain obvious :rolleyes:   Mar 10 2011, 08:26 AM
sean_v8_914   anyone care to speculate as to why turbos are more...   Mar 10 2011, 08:37 AM
Vacca Rabite   anyone care to speculate as to why turbos are mor...   Mar 10 2011, 09:18 AM
J P Stein   anyone care to speculate as to why turbos are mor...   Mar 10 2011, 09:30 AM
Vacca Rabite   anyone care to speculate as to why turbos are mo...   Mar 10 2011, 09:44 AM
Dr Evil   Here is another one:   Mar 10 2011, 08:37 AM
sean_v8_914   is that a 911 turbo?   Mar 10 2011, 08:43 AM
Dr Evil   No   Mar 10 2011, 09:06 AM
Dr Evil   Since my overall intention is to put this into the...   Mar 10 2011, 09:42 AM
rohar   For a low boost bus, I'd go with a small SC. ...   Mar 10 2011, 09:47 AM
Dr Evil   Yup, the plan is the 230 SLK SC to be used :) Chea...   Mar 10 2011, 10:00 AM
rohar   Yup, the plan is the 230 SLK SC to be used :) Che...   Mar 10 2011, 10:43 AM
J P Stein   You may note that I said "proper installation...   Mar 10 2011, 10:00 AM
iamchappy   You may note that I said "proper installatio...   Mar 10 2011, 10:57 AM
J P Stein   An SC is no walk in the park either.   Mar 10 2011, 10:40 AM
Dr Evil   Uh, ya....that is more complicated than I want to ...   Mar 10 2011, 08:49 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:12 PM
