| jim912928 |
Mar 11 2011, 06:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I was fortunate enough that the fuel lines on my engine were fine…so I only had to worry about connections from the engine to supply and return lines. However, I didn’t want to use the old plastic lines and I needed larger diameters all the way from the tank. This sounds easy but it did take a lot of finesse. So, I decided that I would go AN from the tank to the engine (as best I could). I do want to identify several suppliers I used: 1) Pegasus for all the fuel lines, metric to AN adapters (engine return and inlet on the fuel filter) and AN fittings, Tangerine for the stainless tunnel lines with AN fittings on the engine side, JEGS for an AN fuel filter, banjo fitting for the 911 fuel pump (actually a honda part) and a brass reducer coupling I used for the return line up front and finally CB Performance for some really cool metric fuel tank (for VW's and 914's) to AN6 adapters.
| brp986s |
Mar 11 2011, 08:26 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
Tidy little set up you got there. Don't you hate that gigantic fuel filter? Wait till you do a valve adjust. Also, somehow you managed to avoid a huge blob of motronic wiring in the same general area. Maybe cuz the engine isn't in yet. Where did you put the ecu?
jim912928 Fuel lines for a 3.2l with Motronic FI conversion Mar 11 2011, 06:39 PM
jim912928 First the Tank, here are the components I used: VW... Mar 11 2011, 06:47 PM
jim912928 Next I installed Tangerines stainless steel lines ... Mar 11 2011, 06:49 PM
jim912928 Finally, I routed AN6 braided fuel hose (from Peg... Mar 11 2011, 06:51 PM
jim912928 And that’s it...it’s all plumbed up and doesnâ... Mar 11 2011, 06:51 PM
echocanyons Nice job Jim, slick install! Congrats on getti... Mar 11 2011, 08:56 PM
jim912928 brp...the ecu is in the passenger compartment unde... Mar 11 2011, 09:27 PM
davesprinkle
...banjo fitting for the 911 fuel pump (actually ... Mar 11 2011, 09:36 PM
jim912928 Dave...the fuel pump is a 911 fuel pump that came ... Mar 11 2011, 09:48 PM
Racer Chris The last install we did with a pump like that, I f... Mar 12 2011, 06:11 AM
kconway Jim,
Did you use the factory fiber washers at the... Apr 8 2011, 08:07 AM
jim912928 kconway...no I didn't. The AN adapters come w... Apr 8 2011, 08:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:16 PM |
