| mrbubblehead |
Mar 12 2011, 08:17 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
has anyone converted to an electronic speedometer? if so, what did you use for the speed sensor/ring? i was thinking about useing a motorcycle abs ring and attaching it
to one of the cv joints. what set up have you used? any pictures? |
| mrbubblehead |
Mar 13 2011, 10:39 AM
lots of good ideas. thank you every body. so far the cv ring from pacific customs is still in the lead. i was thinking i could cut it in half and bolt it on in 2 pieces. that way i wouldnt have to remove the cv joint.
mrbubblehead electronic speedometer Mar 12 2011, 08:17 PM
mrbubblehead do our stock 914 cv joints have the same bolt patt... Mar 12 2011, 08:31 PM
mrbubblehead im thinking about something like this http://www.p... Mar 12 2011, 09:57 PM
kg6dxn
im thinking about something like this http://www.... Mar 12 2011, 11:40 PM
SirAndy I know i have seen adapters that plug into the spe... Mar 13 2011, 01:51 AM
jimkelly i believe 914 cv and type 1 cv is same bolt patter... Mar 13 2011, 05:01 AM
Phoenix-MN
has anyone converted to an electronic speedometer... Mar 13 2011, 10:29 AM
turnaround89 go here speedometersolutions.com
if prices haven... Mar 13 2011, 01:42 PM
gothspeed I have been looking at some options myself and was... Mar 13 2011, 02:30 PM
BIGKAT_83 I have added a electronic speedo to my subaru 914 ... Mar 13 2011, 04:28 PM
mrbubblehead nice...i figured im not the first one to do such a... Mar 13 2011, 07:36 PM
sww914 You can install a rubber freeze plug from any auto... Mar 13 2011, 07:53 PM
mrbubblehead
You can install a rubber freeze plug from any aut... Mar 13 2011, 07:56 PM
sww914
You can install a rubber freeze plug from any au... Mar 13 2011, 09:41 PM
gothspeed
im thinking about something like this [url=http:/... Mar 13 2011, 09:25 PM
mrbubblehead so here is the inductive pickup that i came up wit... Mar 27 2011, 07:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:09 PM |
