> electronic speedometer
mrbubblehead
post Mar 12 2011, 08:17 PM
Twodollardoug
has anyone converted to an electronic speedometer? if so, what did you use for the speed sensor/ring? i was thinking about useing a motorcycle abs ring and attaching it
to one of the cv joints.
what set up have you used?
any pictures?
sww914
post Mar 13 2011, 07:53 PM
You can install a rubber freeze plug from any auto parts store, had one in my racecar tranny for 12 years. You need to put a shorter 8mm bolt in the retainer bolt hole and a sealing washer because gear oil will leak out of there.
mrbubblehead   electronic speedometer   Mar 12 2011, 08:17 PM
mrbubblehead   do our stock 914 cv joints have the same bolt patt...   Mar 12 2011, 08:31 PM
mrbubblehead   im thinking about something like this http://www.p...   Mar 12 2011, 09:57 PM
kg6dxn   im thinking about something like this http://www....   Mar 12 2011, 11:40 PM
SirAndy   I know i have seen adapters that plug into the spe...   Mar 13 2011, 01:51 AM
jimkelly   i believe 914 cv and type 1 cv is same bolt patter...   Mar 13 2011, 05:01 AM
Phoenix-MN   has anyone converted to an electronic speedometer...   Mar 13 2011, 10:29 AM
mrbubblehead   lots of good ideas. thank you every body. so far t...   Mar 13 2011, 10:39 AM
turnaround89   go here speedometersolutions.com if prices haven...   Mar 13 2011, 01:42 PM
gothspeed   I have been looking at some options myself and was...   Mar 13 2011, 02:30 PM
BIGKAT_83   I have added a electronic speedo to my subaru 914 ...   Mar 13 2011, 04:28 PM
mrbubblehead   nice...i figured im not the first one to do such a...   Mar 13 2011, 07:36 PM
sww914   You can install a rubber freeze plug from any auto...   Mar 13 2011, 07:53 PM
mrbubblehead   You can install a rubber freeze plug from any aut...   Mar 13 2011, 07:56 PM
sww914   You can install a rubber freeze plug from any au...   Mar 13 2011, 09:41 PM
gothspeed   im thinking about something like this [url=http:/...   Mar 13 2011, 09:25 PM
mrbubblehead   so here is the inductive pickup that i came up wit...   Mar 27 2011, 07:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:13 PM
