> Name the root cause:, engine cut out
Fuel Injection Brain [ 0 ] ** [0.00%]
Coil [ 1 ] ** [3.85%]
Pinched hose under gas tank [ 7 ] ** [26.92%]
Fuel Injection Harness [ 1 ] ** [3.85%]
Trigger Points [ 2 ] ** [7.69%]
Main wiring Harness [ 1 ] ** [3.85%]
Distributor [ 2 ] ** [7.69%]
Bad Ground [ 11 ] ** [42.31%]
Spark Plug Wires [ 1 ] ** [3.85%]
Power Off Switch (race type) [ 0 ] ** [0.00%]
Total Votes: 26
Guests cannot vote
porsche735
post Apr 10 2003, 04:36 PM
We have had an issue with our car since we bought it 7 years ago. We noticed it a few times right after we bought it (actually on the way home from the purchase) and it has progressively gotten worse. We have replaced many things over those years to no avail. The problem would go away for a while and then come back. It was basically a "bucking" or cutout that we would get mostly in left hand turns and more so at high RPMs and when it was hot. Going straight it would fix itself in a while and if you made a right turn it would cure immediately. If you shifted to a higher gear, it would go away more quickly. Bitch of a problem.
We have now cured the problem. Which root cause do you think it was? I'll give the answer after this weekend.
Chris
1973 914 2.0L BP
post Apr 10 2003, 04:49 PM
Resident German
i voted for "Pinched hose". the left turn/right turn very much sounds like lack of fuel, cause by a pinched hose. tank wasn't tied down correctly? moved in corners a bit to cut off fuel?
can't wait to hear the answer (IMG:style_emoticons/default/smash.gif)
- Lo-Fi Version Time is now: 6th July 2025 - 10:09 AM
