How Do You Remove This Fan?, Without Breaking it!!! |
kconway |
Mar 14 2011, 08:49 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
How do you remove this without breaking it? I hear the mag is pretty fragile. I tried tapping on the "hub" from the backside but it didn't budge.
Kev |
SLITS |
Mar 15 2011, 08:39 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Kevin ..... flat file the mushroomed part of the shaft to size, then use a thread file (triangular file) to clean the starting threads for the nut or obtain a die the correct size / thread pitch. (I don't know what it is).
If you need another, I need to know what alternator you have. Bosch, SEV Marachal, Rhone Paris, Motorola ..... etc. There are a couple of different ones with different mounting depths. |
kconway |
Mar 15 2011, 10:59 AM
Kevin ..... flat file the mushroomed part of the shaft to size, then use a thread file (triangular file) to clean the starting threads for the nut or obtain a die the correct size / thread pitch. (I don't know what it is). If you need another, I need to know what alternator you have. Bosch, SEV Marachal, Rhone Paris, Motorola ..... etc. There are a couple of different ones with different mounting depths. I'll try to fix it up, I think I have a file that will do the trick. Damn threads are sooo fine on this thing, not sure I can find another nut. Oh yeah, the nuts f'd also from trying to restart the threads. If I'm not successful, it is a SEV Marachal alternator. Kev |
Lo-Fi Version | Time is now: 9th June 2024 - 09:31 PM |
