> Carbs or Ing Sys, Intermittent miss-fire
Razorbobsr
post Mar 14 2011, 11:26 AM
As you guys said, cleaned jets in carb, replaced plugs and wires, smooth at 900 rpms in drive, smooth at 2/3/4 K rpms in driveway, pulls hard W/O, sill I have a miss-fire that I can feel coming and going[surging, sound of engine when all 4 hit at proper times] Could I have a coil prob? Or where off to next?? 2L/carbs/5K sense rebuild/1500 miles driven to get this car home..... NKG plugs but do have Bosh plugs waiting...... Getting warmer outside, Help! Bob PS, British car friends are starting to make fun of the 914........... AND ME
VaccaRabite
post Mar 15 2011, 08:04 AM
En Garde!
Coils usually either work or don't work. I've not heard of coils being intermitent.
If you pull the plug and look at the tip, what does it look like? Is it a nice brown color, or wet and black?
What kind of dizzy do you have? If points, are you sure that your points are set and dwell is correct?
Zach
Razorbobsr
post Mar 16 2011, 08:57 AM
QUOTE(Vacca Rabite @ Mar 15 2011, 10:04 AM) *
Zach
Car started easy this am, fuel mix screw in+ rich?..... Screw out= lean? Still dont see where to disconnect cross bar to syn carbs better. Ran both idles out till eng slowed, both in.... till eng just did pick up rpms a hair, then back a 1/2 hair. One was pretty far off the other, I think? At start I reved it a little can could hear spitting ever so slightly back threw A carb.... poss both, stopped when engine warmed. Normal?
Razorbobsr   Carbs or Ing Sys   Mar 14 2011, 11:26 AM
Vacca Rabite   Where in the rpm range is it missing? Is it missi...   Mar 14 2011, 04:10 PM
Razorbobsr   Where in the rpm range is it missing? Is it miss...   Mar 14 2011, 04:58 PM
Vacca Rabite   Can you get it to miss sitting in your driveway? ...   Mar 14 2011, 07:31 PM
Razorbobsr   Can you get it to miss sitting in your driveway? ...   Mar 14 2011, 09:04 PM
Vacca Rabite   Coils usually either work or don't work. I...   Mar 15 2011, 08:04 AM
Razorbobsr   Coils usually either work or don't work. I...   Mar 15 2011, 10:34 AM
Razorbobsr   Coils usually either work or don't work. I...   Mar 16 2011, 08:57 AM
indianmort   if the misfire develops after the car has warmed u...   Mar 15 2011, 08:23 AM
Razorbobsr   if the misfire develops after the car has warmed ...   Mar 15 2011, 11:39 AM
Borderline   How did you synch the carbs/linkage? I have found...   Mar 15 2011, 10:24 AM
Razorbobsr   How did you synch the carbs/linkage? I have foun...   Mar 15 2011, 11:36 AM
McMark   009 Dizzy is garbage. As Dave Darling loves to sa...   Mar 15 2011, 11:42 AM
Razorbobsr   009 Dizzy is garbage. As Dave Darling loves to s...   Mar 15 2011, 01:37 PM
McMark   Normally I retype all this info. But there is so ...   Mar 15 2011, 02:33 PM
Razorbobsr   Normally I retype all this info. But there is so...   Mar 16 2011, 06:18 AM
Vacca Rabite   Always adjust carbs when they are fully warmed up....   Mar 16 2011, 09:30 AM
Razorbobsr   Always adjust carbs when they are fully warmed up...   Mar 16 2011, 02:42 PM
McMark   Zach, you're confusing two screws here. The ...   Mar 16 2011, 11:24 AM
Vacca Rabite   Zach, you're confusing two screws here. The...   Mar 16 2011, 07:34 PM
- Lo-Fi Version Time is now: 7th July 2025 - 02:33 PM
